External Slave Conversion Problems - JeepForum.com
post #1 of 25 Old 01-23-2014, 09:09 AM Thread Starter
jesmac13
Hey, I just finished up converting my 93 YJ (4.0 w/ AX15) to an external slave set-up and I'm having some issues with the clutch not fully engaging after shifting and releasing the clutch pedal. The clutch will disengage (near the bottom of the pedal travel) and will shift into gear fine, but once I start moving everything starts vibrating pretty bad, and gets worse with speed. If I'm moving and push the clutch in, the vibration stops. To me, that means the clutch isn't engaging fully. Any ideas on what to check? Or is something else going on? The clutch and pressure plate are relatively new, and it was working fine before the swap. I bought a new master/slave kit, and a new throw-out bearing. The bearing retainer, clutch fork, and bell housing were bought used. Any help is appreciated.
I did a search only found issues with not being able to get into gear following this swap.
jesmac13 is offline
post #2 of 25 Old 01-23-2014, 11:06 AM
Que89YJ
Did you tighten the t mount bolts?
Que89YJ is offline
post #3 of 25 Old 01-23-2014, 11:20 AM
Siva283
What did the bellhousing come off of? Are you sure you used the correct pilot bushing? And lastly are you absolutly positive there is no air in the lines. You symptoms are the same as mine where when my master went and again when my slave went.
Ask me how I know...
Siva283 is offline
post #4 of 25 Old 01-23-2014, 11:47 AM Thread Starter
jesmac13
Don't recall the year on the bellhousing. I didn't change the pilot bushing. I did realize after looking at some pictures that the slave is installed upside down (I put the screw pointing down ). I'll flip it around tonight and see if that fixes it. Also - what's the best way to bleed it?
jesmac13 is offline
post #5 of 25 Old 01-23-2014, 11:47 AM Thread Starter
jesmac13
Should be tight
jesmac13 is offline
post #6 of 25 Old 01-23-2014, 12:19 PM
Siva283
Hold up. There should be 2 bolts holding the slave on and it can be eithier orientation. There should not be a bleeder on the slave. To bleed it you aim the pistion down and push it in slowly and it will come back out on its own. Dont let it come all the way out. Do that 10 or 15 times and the slave is bled assuming you have no leaks.
Siva283 is offline
post #7 of 25 Old 01-23-2014, 12:20 PM
Siva283
If there is only one screw or bolt holing it on you are missing one and that is your problem. There should be one on the top and one on the bottom.
Siva283 is offline
post #8 of 25 Old 01-23-2014, 03:26 PM Thread Starter
jesmac13
I was referring to the orientation of the small allen screw that's on the back of the slave (near the hose). Its bolted on with two bolts. I'll give bleeding a try. Thanks for the help so far.
jesmac13 is offline
post #9 of 25 Old 01-23-2014, 07:58 PM Thread Starter
jesmac13
Tried bleeding as you suggested. Definitely got some air out and the pedal feels a little tighter, but no change with the vibrations.
Back to Que89YJ's question though - only 3 of the 6 skid plate bolts are in (the other 3 broke). I had intended to drive it to a welder to get it fixed. Think that's allowing the tranny to flex to much?
Any other thoughts?
jesmac13 is offline
post #10 of 25 Old 01-23-2014, 08:07 PM
rambo3489
Bleeding was good. I doubt missing the skid bolts would affect anything. What year were the trannies? Maybe your pilot bearing is a .75 and your tranny tip is a .580 or whatever the small one is?
Or maybe the pilot bearing is shot?
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #11 of 25 Old 01-23-2014, 08:26 PM
whiskeywiz
Is it running on all cylinders? Not trying to be a wise guy, just that I did a tune up on my daily driver and replaced the spark plug wires just recently. After driving for a couple of days it started running like hell, vibrating terribly at higher speeds. I must have run the wires carelessly because I pulled over to take a look under the hood and the no. 1 wire was pulled right out of the boot! The steering shaft must have grabbed it.
whiskeywiz is offline
post #12 of 25 Old 01-24-2014, 08:51 AM Thread Starter
jesmac13
Transmission didn't change, only replaced the bellhousing, so pilot bearing should be unaffected. Pilot bearing was replaced maybe 10k miles ago, so it should be fine.
jesmac13 is offline
post #13 of 25 Old 01-24-2014, 08:56 AM
Que89YJ
Fix the trans bolts. If the mount allows any movement it would explain the vibration.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 25 Old 01-24-2014, 10:02 AM
Siva283
Same crank same trans. He only change the bellhousing so the pilot bushing should be right.
Siva283 is offline
post #15 of 25 Old 01-24-2014, 10:03 AM
Siva283
Originally Posted by que89yj View Post
fix the trans bolts. If the mount allows any movement it would explain the vibration.
x2
Siva283 is offline
