External to Internal Slave - JeepForum.com
post #1 of 9 Old 09-17-2011, 04:07 PM Thread Starter
95wrangler4life
So my question is this, when converting what do I have to do?
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #2 of 9 Old 09-17-2011, 04:15 PM
shadowulf
Wait, let me get this right.
You want to go FROM an external slave TO an internal slave?
Sorry, but why do you want to do this?
" All jeeps are destined to be the parts pile for the next project" :Unknown
shadowulf is offline
post #3 of 9 Old 09-17-2011, 04:22 PM Thread Starter
95wrangler4life
my ax5 is sh*t... syncro's in all 5 are done, my buddy just offered me his AX5 but it is internal.... I know nothing about the benefits of either, so if someone can explain that would be great.
otherwise if its wrong to go to internal or worse... then i will just keep grinding them since its a trail rig
Build thread:
post #4 of 9 Old 09-17-2011, 04:49 PM
nembudonna
Just take your bellhousing off and put it on the trans. Then you can use all your parts so it's external. All you want is the trans. Sure don't want an internal.
nembudonna is offline
post #5 of 9 Old 09-17-2011, 04:54 PM
shadowulf
Ok, that makes more sense
post #6 of 9 Old 09-17-2011, 04:56 PM
dancytron
The problem with the internal is you have to take out the transmission to change it. The external you can change in your driveway in 20 minutes.
dancytron is offline
post #7 of 9 Old 09-17-2011, 05:00 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Take the bellhousing & front bearing retainer off of your external slave unit, install them on the internal slave. Swap transmissions.
You now have a newer transmission that doesn't grind, without having to swap to the inferior (and stupid) internal/concentric slave cylinder setup. It was a dumb idea when Mazda did it, it stayed a dumb idea when Ford did it, and the story does not improve with telling.
There's much greater difficulty in getting the concentric slave to seal than the conventional slave, and to replace the slave you must remove the transmission!
Since it's going to be relatively easy for you to change over the transmission to accept the current hydraulics, and you'll have both units in front of you, there's no reason to not do it.
Simply swap the bellhousing & associated parts over to the replacement box. With both of them on the bench in front of you, it's easy - just remove the parts that are different on the box you've taken out and put them on the replacement.
It's also much cheaper than having to swap hydraulics anyhow - which is what you'd be looking at.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 9 Old 09-17-2011, 05:02 PM
nembudonna
To explain it to you why you don't want an internal. Because the slave on an internal is inside the bell houseing,and when it goes bad,as they often do, you have to pull the trans to replace it. On yours is right on the out side. Take the trans and swap it for yours, but just the trans.
post #9 of 9 Old 09-18-2011, 01:24 AM
Fenix85182
Fenix85182's Avatar
Make sure you look at the new tranny and the old tranny side-by-side to see that everything matches. When I swapped to a newer AX15 from an old one to swap from internal to an external slave, I found out the external slave had a smaller pilot than the internal. There might be a trip to make some custom parts at the machine shop, but it would be worth it.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
Internal or external slave? XsaltlifeX YJ Wrangler Technical Forum 2 09-23-2009 08:15 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 11:26 AM
Internal or External Slave Cyl 73Dart YJ Wrangler Technical Forum 6 04-15-2009 10:57 PM
Internal Slave to External teaser73 YJ Wrangler Technical Forum 6 01-26-2009 12:36 PM
Internal or external slave? Sawbladz TJ Wrangler Technical Forum 3 05-14-2007 12:15 PM
