explorer procomp coil spring conversion - JeepForum.com
post #1 of 3 Old 05-31-2003, 11:21 AM Thread Starter
jt_Jeep
anybody has used this kit?? and how's the performance???
what's the pro's and con's??
thanks a lot
'95 Wrangler 2.5L Rio Grande, Tera Low T-case 4:1, 5" Procomp Coil Spring Conversion, ARB front & rear locker, TJ passenger inner axle shaft, Advance Adapters HD SYE & HD drive shaft, 4.0 TB, 8mm spark plugs wire, platium +4 sparks plug, MSD Coil, Sanden OBA / 2.5 Gallon tank, 33" Goodyear MT/R, K&N filter, Flowmaster, 16" Electric fan.
- http://photos.yahoo.com/jete_cobra
jt_Jeep is offline
post #2 of 3 Old 05-31-2003, 11:54 AM
Meister_jeep
you might want to look on the net there is a good writeup on this subject that a guy who did the conversion wrote a while back
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #3 of 3 Old 06-01-2003, 12:33 AM Thread Starter
jt_Jeep
I did some search on the net...just want to hear it from someone in the forum.
thanks again...
jt_Jeep is offline
YJ Coil Spring Conversion goosevodka YJ Wrangler Technical Forum 47 11-12-2016 07:56 AM
coil spring conversion? saharajeepn YJ Wrangler Technical Forum 3 07-25-2004 11:10 AM
coil spring conversion JeepersCreeper YJ Wrangler Technical Forum 5 06-25-2003 07:53 AM
coil spring conversion JeepersCreeper YJ Wrangler Technical Forum 1 06-21-2003 09:07 AM
Procomp coil spring conversion pk YJ Wrangler Technical Forum 6 01-22-2002 10:37 PM
