Explorer 8.8 Axle Teardown/Rebuild/Install - Page 10 - JeepForum.com
 1Likes
post #136 of 139 Old 03-23-2016, 06:43 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Yeah, I wouldn't be too concerned about causing a reconfiguration of the atoms that make up the fuel tank. Hey, it's only got 200 lbs of highly volitile fuel in it...
Seriously, others have done it. It should be fine.
I had difficulty finding an inch-pound beam style torque wrench. Eventually snagged one from a SnapOn truck while at a friend's shop.
Should come in handy if I ever set up gears again or need to wrench on a NASA approved bicycle at some point...
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #137 of 139 Old 03-23-2016, 08:20 PM
StanF
Originally Posted by Feetwet
Yeah, I wouldn't be too concerned about causing a reconfiguration of the atoms that make up the fuel tank. Hey, it's only got 200 lbs of highly volitile fuel in it... Seriously, others have done it. It should be fine. I had difficulty finding an inch-pound beam style torque wrench. Eventually snagged one from a SnapOn truck while at a friend's shop. Should come in handy if I ever set up gears again or need to wrench on a NASA approved bicycle at some point...
For anyone else following along, those beam type in-lb torque wrenches are easy to find at Amazon. I paid about $35. They're 1/4 drive, so you'll likely need some step-up adapters to get to 1/2 drive
StanF is offline
post #138 of 139 Old 03-24-2016, 05:57 AM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Yup. I didn't start using Amazon til lately.
Just think of all the cool, obscure stuff I was missin out on....
Feetwet is offline
post #139 of 139 Old 03-24-2016, 06:13 AM
fishadventure
Thanks for the heads-up.
I hadn't checked in a while, all the 1/4" options were "not available" last I'd looked. Now there's several options.
The Performance Tool version is 0-60in.lbs. and has a nicer pointer which is what you buy the tool for -to read it- so I'm going with that even though it's $37 vs $23. A have an adapter for both 1-4>3/8 and 1/4>1/2 so I'm good to go. I don't think I've ever used the 1/4>1/2 before?
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
