Exhaust tailpipe for SBC swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Exhaust tailpipe for SBC swap
Rancho Shocktober is here for fall 2015!!!!You Pick the Size and Style of Lift Kit. We will Find you FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 08-20-2015, 06:44 PM   #1
Galligher
I am in the final steps of swapping a 330hp vortec headed 350 into my 1995 Wrangler. I have 2.5" ramhorn exhaust manifolds with 2.5" downpipes that y into a single 3" pipe. My question is after the muffler. Fitting a 3" tailpipe does not look possible. I don't want turndowns or a side exit as I want it to be as streetable as possible. I am thinking it may not be a big deal to have a 2.5" tailpipe and not drop hp by more than a couple. My thought is that the difference in size is 70% (2.5 of 3 in area of a circle). Bringing out the science major in myself, Charles law states that temp and volume are proportional in gases. I am thinking that after the muffler, the temp drop from the start of the y to the back of the muffler has to be 70% drop in temp. If this really is true, that the actual change in size of the exhaust really doesn't change. The potential is that it may increase torque in that exhaust velocity is maintained? Any thoughts?
1995 4Cyl Wrangler - Used to having modified Mustangs, I have to get this thing more guts!
Galligher is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 09:31 AM   #2
Randonexplosion
Randonexplosion's Avatar
I honestly have no input on the science but I am running 2.5" exhaust with my 5.3 and it is fine, though I am more interested in low end power.
5.3/4 link build
Looking for 92+ front female seatbelts
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 03:18 PM   #3
gotswap
would something like this help move it out a bit?
gotswap is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 04:03 PM   #4
87TPIYJ
1987 YJ Wrangler
I have the 2.5" ramshorns and a ypipe. My entire exhaust is 2.5". Mine goes manifold, Y pipe, cat, straight shot to muffler (single in dual out) then tail pipes coming out at a 45 in front of the shackle between the frame and leaf. Here are some pics from when I was building it. Hope this helps.
Sent from AutoGuide.com Free App
87 YJ, 350 TPI, NV4500, 35x12.50x17, SOA, Locked front, 8.8 LSD rear, Flat skid
87TPIYJ is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 04:06 PM   #5
zte87
GIVE IT THE ONION
zte87's Avatar
I am running 3 inch out the back In the stock location So it's possible. I am running 2.5 for the y pipe than 3 inch from there back (high flow cat/ flowmaster ). It's tight but doable!
95 jeep yj double main leaf stock spring soa, locked front and rear 30/8.8 with chromo shafts, full cloak armor and 35 inch mtrk tires
zte87 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 07:49 PM   #6
Galligher
87TPIYJ - Thanks, I thought about running the exhaust out back like yours, through the frame and springs. Have you had any issue of the springs touching. I am SUA though so some differences in spacing. Also, it looks in the pic that the exhaust is pointed at the tire, any issues?
GOTSWAP - Any issues touching the springs? Looks like your lift is big enough that it probably is not an issue. The pipe looks like a "stockish" 2.25" one, but I could be wrong.
ZTE87 - That is great! It is tight but it looks like you have some spacing on both sides. How was the clearance for the 3" pipe over the axle?
Again, thanks! I may go 3" out back if over the axle is not bad, or maybe 3" between the frame and springs... Either would be more quiet than out the side or turndowns and the smell would probably not be much different than the stock motor/exhaust.
Unread 08-21-2015, 08:14 PM   #7
zte87
GIVE IT THE ONION
zte87's Avatar
Originally Posted by Galligher
87TPIYJ - Thanks, I thought about running the exhaust out back like yours, through the frame and springs. Have you had any issue of the springs touching. I am SUA though so some differences in spacing. Also, it looks in the pic that the exhaust is pointed at the tire, any issues? GOTSWAP - Any issues touching the springs? Looks like your lift is big enough that it probably is not an issue. The pipe looks like a "stockish" 2.25" one, but I could be wrong. ZTE87 - That is great! It is tight but it looks like you have some spacing on both sides. How was the clearance for the 3" pipe over the axle? Again, thanks! I may go 3" out back if over the axle is not bad, or maybe 3" between the frame and springs... Either would be more quiet than out the side or turndowns and the smell would probably not be much different than the stock motor/exhaust.
It's very close, it's up high enough to where my bump stops keep my axle off it at full flex. It was dumped under the tub before and I hated it!
Updated with a pic, it barley contacts the axle under full flex (as I said all ready my bump stop prevents this). And I am soa with stock frenched springs......I imagine you would be better off with arched sua setup!
Unread 08-21-2015, 08:30 PM   #8
stevehoj
I also run a mandrel bent 3" tailpipe for YJ and stock location. Call below.
http://www.kolakperformance.com/
Happy motoring.
08 Tundra CrewMax TRD 5.7, 07 Jeep GC-SRT8, 01 Lightning (sold), 96 Impala SS (sold), 93 RX-7 Twin Turbo (sold), 90 Wrangler 413 cid (AMC 401 +0.060), 71 Formula 400 (sold), 72 Formula 350 (sold), 71 Firebird 350 (sold), 69 Firebird 462 cid (455 +0.030)
stevehoj is offline   Reply With Quote Quick reply to this message
Unread 08-22-2015, 08:04 AM   #9
87TPIYJ
1987 YJ Wrangler
It's the illusion of the picture. It's really at a 45 pointing towards the back past the tire. The spring never contacts the exhaust, however at full stuffy tire will touch the tail pipe on one side. I could fix it where it wouldn't, but just been to lazy to.
Unread 08-22-2015, 02:48 PM   #10
gotswap
I think I have pretty much stock diameter pipe but am no where near close to touching anywhere under full stuff. If you want I can go out and take some better pics.
Unread 08-22-2015, 04:38 PM   #11
Galligher
Thanks to all! I see I have many good options.
