Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail.
#1 | |
SO, I'm trying to remove the exhaust manifold and I cannot figure anything out because the Haynes book completly sucks. So, to remove the intake, I have to take out the injectors? OR just the wiring harness that goes to the injectors. And whats the deal, when I disconnect the quick disconnect for the supply and return lines to the fuel rail I need to by an o-ring and spacer kit from the dealership?? And is this the same for each injector???? I have no idea how to disconnect the wires going to the injector and I really don't want to get in there and start trying to things because I really don't want to screw up a fuel injector. Please help me out here... I had no idea how difficult this would be...
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE 1967 FJ, linked, 350 chevy, 35's, arbs, blah blah... 2002 TJ "If you're not moving ahead, you're falling behind" |
#2 | |
H2 Recovery Team Member
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#3 |
When I changed my manifold all I did was disconnect the fuel lines and just moved the fuel rail out of the way. I didn't need to replace the o-rings.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride 1991 YJ Sahara 4.0L Automatic 1978 Dodge Lil Red Express - work in progress |
#4 | |
Which lines? Just the supply and return lines? Did you have to touch any of the injector stuff? Like unplug it atleast? And just unbolt the whole rail from the intake and let it hang-out there? Sorry for the questions, but I don't want to fiddle with that expensive electrical stuff.
#5 |
Hillbilly Member
I am trying to remember what I did when I installed my borla hdr....
I think I left everything mechanically connected and just let it hang. Also the easiest way to remove that exhaust manifold is through the bottom. I did not start messing with any of the intake and fuel injection until I tried putting the borla hdr in because it is alot longer than the factory exhaust manifold and I thought it would be easier to drop it in from the top.....I was wrong I still mananged to manuever it in through the bottom I thought I was going to have to move all that stuff also but I did not need to I know I ended up disconnecting some wires but that was easy, I know I did not disconnect any supply and return lines.
To view the NEW Jeep Encyclopedia click here!!! |
#6 |
I remember just disconnecting the supply and return lines, the two lines towards the front of the Jeep, and then just unbolting the fuel rail from the intake manifold and moving it out of the way.
#7 |
Alright, I'll try it out in a bit. My arm's sore from all the shots they had to give me today at the Dr.'s. Thanks
#8 |
Alright, took out the 4 bolts that holds the rail on. So I'm trying to pull it off and the injectors just won't pop out. Anyone have a trick to get the injectors to pop out? I used Pb blaster and I'm trying and trying and she won't break loose. Which angle do they come out?
#9 |
Well, I figured out a quicker way. All I did was remove the 9 intake bolts and flip the whole manifold up and onto the valve cover. Basically the throttle body was facing the oil cap. Pretty simple now that I'm not using the book. Sometimes that book just makes everything harder. Here's a couple reference shots.
#10 | |
Hillbilly Member
Sorry if I did not explain it well but that is what I was trying to say, you don't have to disconnect any fuel lines or pull any injectors you just move the whole intake manifold. I could not get mine to flip up on top of the valve cover though and the exhaust manifold will just come right from the bottom.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
