#1 | |
Which exhaust manifold to buy?
I'm in the market for a new exhaust manifold. Mine has a couple decent size cracks in it and sounds horrible. But I've been searching on here and some people like the ebay manifold
#2 |
They look the exact same to me
#3 |
Manifolds are notorious for cracking, not a matter of if but when, I'm not sure about the integrity of the aftermarket ones, but if it's out and you are replacing why not spend the few extra bucks on a header? I think I saw some on 4wd.com for fairly reasonable, just a suggustion.
EDIT, just seen this for $50 more, might be worth looking in to- http://www.quadratec.com/products/17604_102_07.htm Good luck! -Bryon |
#4 |
Hmmm......
#5 |
I got this one and it has not cracked in 2 years works just fine and cheap.
Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#6 |
The latest cost on the Ebay manifold I saw was 66 SHIPPED... that may change the equation for you.
I have the Rugged Ridge Stainless header... a lot more money, but I love it.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#7 | |
#8 | |
#9 |
Clifford Performance has a header that looks exactly like a borla and it's stainless for only $250. Would have bought it had I known.
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P. 1993 YJ - Stock 2.5L, Scrapped. R.I.P. [URL="http://www.jeepforum.com/forum/f12/desert-rat-build-830626/"]1994 YJ - Stock 4.0L, Currently getting the frame off treatment and being built up.[/URL] |
#10 | |
You can get the eBay one directly from the seller & skip the eBay BS by going to www.1aauto.com and you'll still get the same price. I've used them in the past & they are good parts at great prices! The folks at www.1aauto.com are good to deal with as well.
Max
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#11 |
I picked up an ebay header for mine a few months ago. Like $175 shipped with gasket. Looks the same as the stainless steel rugged ridge one without the flex pipe sections. It survived having the head pipe pulled and crushed on a rock without any problems. Watch getting one with the flex pipe, everyone of those I've seen has broke at one of the folds.
#12 | |
#13 | |
#14 |
From the ones I've seen running the flex pipe, they prevent cracks to the rest of the manifold by reducing the vibrations from the front and back of the engine. But the flex pipe is normally made of such cheap material that it doesn't hold up to the heat for very long and if you've properly tightened it there shouldn't be any vibrations. I say If you want something that is going to last spend a little, one for $66 isn't likely to be even up to oem standards when quality ones go for well over $200. And you don't see borla, gibson, or banks using the flex pipe on the high dollar units.
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
