exhaust leak where exhaust meets cat - JeepForum.com
post #1 of 4 Old 05-04-2010, 06:56 PM Thread Starter
psyklone
hey fellas,
'92 yj, 4.0
i've got an exhaust leak that i've tracked down to, i'm pretty sure, where the exhaust comes down into the cat. tomorrow i'm going to drop that big shield that's in the way so that i can get to it but i have a question before i get up underneath it. is that a flanged connection, or is there a gasket in there? for that matter, from what i can tell i'm going to need to drop the tailpipe/muffler, and then the cat so i'm wondering if any of these are gasket connections or if they're just flange or clamp style.
thanks!
psyklone is offline
post #2 of 4 Old 05-04-2010, 07:46 PM
Mark05059
Be sure to support the transfer case/transmission when you drop the big shield thing since that is holding them up. There is a gasket inbetween the bolted sections of the exhaust.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 4 Old 05-04-2010, 10:20 PM Thread Starter
psyklone
thanks mark, that's what i was looking for.
psyklone is offline
post #4 of 4 Old 05-04-2010, 10:43 PM
warthog312
i know its kind of ghetto, but i have used seafoam to pinpoint exhaust leaks in the past. dump it in, let it sit, then look for the white smoke pouring out of where it's not supposed to be! it helps when you are doing your own welding. that being said, i wouldnt do it more then every once in a blue moon, when all other options are exhausted.
warthog312 is offline
New jeep owner! (exhaust leak and oil leak) Mindcrime13 TJ Wrangler Technical Forum 9 03-04-2010 01:34 PM
exhaust leak between header and exhaust piping 03rubiconMG TJ Wrangler Technical Forum 7 06-11-2009 08:02 AM
exhaust leak bigj1974 TJ Wrangler Technical Forum 11 04-06-2008 06:28 PM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
Exhaust leak already??? franco802 TJ Wrangler Technical Forum 4 11-04-2003 04:29 PM
