Exhaust leak? And Fuel injector Question
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
1.Ok sounds like an exhaust leak, and faint smell after idling in cab of exhaust fumes. But when idling i cant hear the clicking noise, only happens it i get into the trouble hard. But slow acceleration it doesnt make the sound. Is it exhaust, and if so how hard is it to change gasket. I tightened the bolts already and everything was tight, cant see any visible opening alone the piping.
2. Previous owner said i would need to put a new fuel injector soon. I am not sure why but im guessing its never been replaced. 157,XXX miles. Does it need replacing, or what? Also my other question, is the injector inside the Carb/TBI unit.
#2 | |
i had a similar problem a year ago. i had exhaust coming into the cab through the dash vents for the defroster. it ended up being a bad head gasket.
to change the gasket, it should not be a difficult task whether it is the head gasket or exhaust manifold. you will, however, need to get a new set of bolts for either place you change a gasket (they say you should change the bolts each time so they will keep their tightness after being torqued down.) good luck ![]()
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield RED JEEP CLUB MEMBER 536 Originally posted by Crazyquadder: Quote:
#3 | |
don't know about the fuel injector. but unless its a custom setup, yj's didnt have fuel injection until 1991
#4 | |
"The Throttle body fuel injection is used on 1987-1990 wranglers equipped with 2.5L engine and is a pulse time system that uses a single solenoid-type injector to meter fuel into the throttle body above the throttle plate" Section 5-5 Chilton Wrangler/ YJ 1987-1995 Repair Manual |
#5 |
My 1990 YJ has a single injector in the throttle body.
jeepsurf endorses this post. Most of the time Admin, nightcrew.org 1990 2.5 YJ / 1997 2.5 TJ USAF VET |
#6 | |
well good, thanks for some new knowledge about the older YJs.
#7 |
#8 | |
look for a copy on the internet of your owner's manual, maybe it would have some more descriptions of the pictures
#9 |
Take the air duct off the throttle body and look in the center. that is the injector. The duct hose goes from the air filter box to the TBI, resembles a carb.
#10 |
yeah, like everyone is saying the injector is in the carb, the easiest way would to probably follow the fuel line to the injector. but before i go replacing anything id run some fuel injector cleaner through a tank first (b12 chemtool works awesome) b/c i dont know howd you can foresee a fuel injector failing.....
also if it is an exhaust leak that will cause the rig to run rich b/c of the extra oxygen entering your exhaust system |
#11 |
It doesnt run that much rich, just its an annoying sound.
As for the injector i see what it is now, and that is true i dont know how you could foresee one going bad, how long do the original ones last time its time to replace them? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
