exhaust leak - JeepForum.com
post #1 of 4 Old 04-20-2013, 10:57 AM Thread Starter
freeman2692
exhaust leak
hey, everyone
I think I have a small exhaust leak was wondering whats the best way to fix it and also does it have any major effect to having it other then the sound
Thanks for the help, Josh
freeman2692 is offline
post #2 of 4 Old 04-20-2013, 03:48 PM
NonRubicon
An exhaust leak that occurs upstream of an O2 sensor will produce a false O2 reading and mess with the fuel delivery. If carbureted and not using an O2 sensor then it won't have too much effect on fuel delivery, but maybe a little on backpressure and low end torque.
Cast iron exhaust manifolds are tricky to weld up properly and probably just easier to replace because cracks usually end up warping the manifold. Stainless steel can be welded if you know what you are doing.
NonRubicon is offline
post #3 of 4 Old 04-20-2013, 04:56 PM
Chrisnvegas
Chrisnvegas's Avatar
Fill in your profile. We don't know if your Jeep is a four banger or a six.
Six bangers have a defective exhaust manifold. Mine just cracked while at the dunes a few weeks ago. I could weld it but it would just crack somewhere else. They sell a replacement with expansion joints for around a hundred bucks or so.
If you have a four banger, I'm sure other people know about them.
Ban computer updates and autoplay video! Boycott music without real instruments and singers using autotune.
Chrisnvegas is offline
post #4 of 4 Old 04-22-2013, 10:31 AM
Flajeeper1
1987 YJ Wrangler
Let's start with where the exhaust leak is. Exhaust manifold to engine, downpipe connection to the exhaust manifold?
Flajeeper1 is offline
