exhaust/intake - JeepForum.com
post #1 of 6 Old 12-01-2011, 07:50 AM Thread Starter
chris447
exhaust/intake
Whats a good fairly priced set up?
chris447 is offline
post #2 of 6 Old 12-01-2011, 11:10 AM
moonshinefuel
As in cold air intake? And performance exhaust?
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 6 Old 12-01-2011, 11:19 AM
Alfons
In my opinion, the best intake for a 4.0 that you can get would be the intake manifold from a 2000+ I6. It'll give you a lot more air & is designed to give a lot less internal turbulence and all this gives you some real bolt-on horsepower. Much of the other stuff on the market is nothing more than "bling" - a shiny pipe with a visible filter, and these won't give you any measurable power increase.
Alfons is offline
post #4 of 6 Old 12-02-2011, 05:05 AM Thread Starter
chris447
Is this a direct bolt up? And what about exhaust.... i like how my stock set up is for mud, but want power and some rumble.... my stock intake mod was putting a 90deg exhaust pipe strait up to about 2 inches beloew the hood from the hole in the bottom of air box, sealed it off and put a piece of "cat" prefilter on the top to keep debrie out
chris447 is offline
post #5 of 6 Old 12-02-2011, 10:19 AM
444
I agree. The aftermarket cold air intakes are nothing more than a good marketing gimmick to make some pure profit. The stock 4.0 exhaust manifold is pretty decent too. You can change your exhaust and/or muffler but all you'll really do is change the sound.
444 is offline
post #6 of 6 Old 12-03-2011, 06:38 AM
dodger889
ALL you guys that are looking for more performance from a 4.0. tear down the engine and blue print it. You might gain a little from that. Polish your intake runners, port the heads and intake , exhaust. You might gain a few extra ponies from that, change injectors, Clean up what the factory did not do to make the engine to it's max power. Then when you get all said and done you have spent better than 2 grand on the motor or more. You still have a 4.0 that might run a little smoother have just a touch more power and a little better torque curve.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Intake/Exhaust davsyjdd YJ Wrangler Technical Forum 3 11-18-2011 10:37 AM
exhaust out the intake???? jeepwrangler97 TJ Wrangler Technical Forum 6 09-28-2010 04:08 PM
Exhaust/Air Intake razorbladex401 TJ Wrangler Technical Forum 19 10-21-2006 06:37 AM
intake and exhaust jknutter TJ Wrangler Technical Forum 20 08-30-2006 10:25 PM
exhaust and intake JeepKidd TJ Wrangler Technical Forum 8 08-23-2004 06:35 AM
