exhaust headers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > exhaust headers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 02-09-2015, 08:15 PM   #1
superduty06
exhaust headers
will the 4.0 exhaust fit the 4.2 or the 4.2 fit the 4.0? I would like to put a exhaust header on my 4.2 hard to fined headers that fits 4.2s can fined a lot of them for a 4.0.
superduty06 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 08:36 PM   #2
88_olympic
I do not believe The header from a 4.2 258 will not fit the 4.0 motor. The intake and exhaust ports on a 258 are all even with each other. On a 4.0 the intake and exhaust are staggered. I think you will run into fitment issues if you tried to swap.
88_olympic is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 06:17 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Nope, different designed head. The intakes will swap with a little tweak, but not the exhaust.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 02-10-2015, 07:56 AM   #4
Rebel442
Dont know why you cant find 4.2 headers there are several brands out there from budget to high end. Off the top of my head Borla, Hedman, Pacesetter, and Clifford all make them.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 07:15 PM   #5
bergovoy
the OP is correct. not a lot of options for the older YJ exhaust manifold/header.
morris4x4 has the ONLY one I have found so far....
if anyone has other options, please let me know...
btw, I'm california and need the O2 bung.. thanks
bill
bergovoy is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 07:42 PM   #6
Rebel442
Borla
http://www.borla.com/products/wrangl...rt__17062.html
This one is installed on my '89 auto trans
PaceSetter
Uncoated
http://pacesetterexhaust.com/87-90-j...r-headers.aspx
Coated
http://pacesetterexhaust.com/87-90-j...d-headers.aspx
Clifford
http://www.cliffordperformance.net/M...gory_Code=J258
Not sure of an O2 bung on this one. Any decent shop can weld one in for a reasonable fee.
Looks like I was wrong about Hedman.
4.2l CJ headers will fit, However there may be some fitment issues with intake manifold thickness(spacers), O2 bungs(easy to add), EGR valves(eliminate), carb heat risers(eliminate) , pulse air systems(eliminate), and auto trans linkage clearance issues. If you have tough visual emissions issues they may not be for you.
Unread 02-18-2015, 07:45 PM   #7
synwill
Borla makes one and they are based in California. Just make sure that the EO number that is stamped on the header matches your year. I installed mine and then the smog station said it was the wrong EO for my year so I had to have Borla send me the correct EO and then I had to tack weld it on after installing. Pain in the rear.
synwill is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 10:17 PM   #8
bergovoy
yea, I actually found those previously and forgot about them... I was surprised that hooker and hedman didnt have anything... and a few others... not sure why...
and yea, the bung can be added but it will get shot down by the visual inspection... as will the pulse air system... Ive heard they don't care about the hot air riser and carb choke isnt as much of an issue, (as we are in sunny so california... )
thanks for posting the links btw...
