Exhaust Header Madness!! - JeepForum.com
post #1 of 10 Old 03-14-2006, 08:19 AM Thread Starter
bamato
bamato's Avatar
I just put a new header on my exhaust by pacesetter. It comes with these little step washers to compensate for the difference in thickness in the flange of the exhaust and the intake. But on the bottom of the engine where the header bolts are barely visible its difficult to line them up correctly. It's hard enough just to get a wrench in there. So my exhaust leaks like nothing else and sounds like poo. Anyone have any suggestions to make sealing my exhaust easier? Thanks!
bamato is offline
post #2 of 10 Old 03-14-2006, 09:42 AM
Why J?
Why J?'s Avatar
TAKE EV.... OMG MY CAPS LOCK IS ON!!!!!!!!!!!!!!!!!!!!!!!! Take everything out of the way, intake manifold, throttle body, powersteering pump and it will go in a lot easier.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #3 of 10 Old 03-14-2006, 10:04 AM Thread Starter
bamato
bamato's Avatar
the main problem though is that the header itself is in the way. On the cylinder pipes's downward angle it blocks off the bolt holes that I need to tighten. I'm just hoping there is some secret trick that people do to seal leaky exhaust
bamato is offline
post #4 of 10 Old 03-14-2006, 11:54 AM
pushead
I took mine to a local shop and had them do some repiping to make every thing fit propely. Got frm the header to the cat repiped for $100. Money well spent.
Its not a jeep if it dont have 4wd.
pushead is offline
post #5 of 10 Old 03-14-2006, 01:59 PM
mrbigglesworth
mrbigglesworth's Avatar
can you post some pictures of what you need to tighten?
?[]|||||||[] Black 1990 YJ 4.2L 6cyl 5spd []|||||||[]
BLACK JEEP CLUB #1000
Mods:
3.5" Rough Country Lift Kit
2 inch shackle lift
JKS Telescoping front track bar
33"x13.5" Super Swampers with 15" x10" AR Wheels
Front and Rear Auto Lockers
SYE and CV shaft in rear
Motorcraft Carb Conversion
Imperial Electric Cooling Fan
Grill Guard Front Bumper
Hella Bumper Lights
Rear Towing Crossmember and Hitch
Diamond Plate Running Boards
CB Radio
mrbigglesworth is offline
post #6 of 10 Old 03-14-2006, 02:01 PM
Why J?
Why J?'s Avatar
unbolt it fromthe exhaust down tube, that is probably what is taking it out of alligment.
Why J? is offline
post #7 of 10 Old 03-14-2006, 03:42 PM
ncjeepinyj
ncjeepinyj's Avatar
Are you talking about the header pipes or the mounting flange that actually bolts to the head. After i bolted mine up the mounting flange overlapped some of the bolt holes for the intake and i had to take the header back off and grind it down so the other bolts would fit, BTW, did i mention that pacesetter headers SUCKASS!!!!! Just wait till you see where the rest of the pipe ends up.
95 YJ, SOA, 35's, 4.88's, 8.8
ncjeepinyj is offline
post #8 of 10 Old 03-14-2006, 03:47 PM
pushead
This is why I recomend taking it to a muffler shop. I could not agree more with the comment. Thats what we get for being cheap.
pushead is offline
post #9 of 10 Old 03-14-2006, 08:08 PM
ncjeepinyj
ncjeepinyj's Avatar
Yeah, in the end it doesnt pay off. I ended up paying $90 just to have the rest of the exhaust routed so it wouldnt get ripped off the first time i take it off road. Guess i am the one that got ripped off. BTW, pacesetter customer service SUCKSASS too. I emailed, called and was even told to send pics of my problem and 2 weeks later still no word back from them. When ever i run into a product or company this bad, yes, i will do my best to make it known.
post #10 of 10 Old 03-14-2006, 09:00 PM Thread Starter
bamato
bamato's Avatar
well I was ingenient enough to run all y own custom downpipes and such. It actually looks and sounds remarkable beautiful. And to answer the question earlier, It's the flange that bolts to the block where the problem is. Just cant quite get it to seal right. Any ideas ya'll? And yeah, Im pretty cheap as well
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
Exhaust header mrblaine TJ Wrangler Technical Forum 19 04-15-2011 10:58 PM
exhaust leak between header and exhaust piping 03rubiconMG TJ Wrangler Technical Forum 7 06-11-2009 08:02 AM
Best header & exhaust ImNotStuck TJ Wrangler Technical Forum 5 05-03-2009 06:32 PM
What header and exhaust to get for a 99 4.0L smee44 TJ Wrangler Technical Forum 2 01-28-2009 06:30 PM
Exhaust Header sequel YJ Wrangler Technical Forum 13 10-23-2006 08:44 PM
