Exhaust Hanger, isolator on transmission 4.2 stock exhaust - JeepForum.com
post #1 of 6 Old 07-20-2009, 12:19 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
After putting up my stock exhaust, I noticed that where it goes up and over the skid plate and passes by the transmission there looks to be some typ
e of exhaust bracket. I'm assumming it because the pipe fits right in it. It is a C shape bracket with 2 holes in it. Is there suppose tobe some type of bracket or clamp or isolator whatever you want to call it attached to this. I hate it cause everytime I let the clucth out in reverse I swear I hear the stupid thing bang the pipe. Its annoying. It is a 5 speed manual..if wondering in an 87 Wranger.
Thanks,
Chris
Chris Aunchman is offline
post #2 of 6 Old 07-20-2009, 12:57 PM
bparsel
2011 JK Wrangler
I can look when I get home but I'm sure someone will chime in before then.
I have the same issue on mine, I have re-hung the exhaust about 8 times and no matter what every once and awhile when I take off from a stop to fast that thing will bang loud as he!! down there on the crossmember. Frickin annoying.
bparsel is offline
post #3 of 6 Old 07-20-2009, 05:33 PM
ctm
There is a bracket that attaches to the exhaust right at the square fitting where the downpipe meets the cat. That is a C shape that goes into a C shaped rubber isolator bracket that is attached to the tranny or skidplate.
see parts 10 + 11:
ctm is offline
post #4 of 6 Old 07-20-2009, 05:58 PM
Burnerman
Burnerman's Avatar
Here's a pic or 2 of what it looks like..
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 6 Old 07-20-2009, 10:35 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
Makes sense when putting back up the exhaust I didn't use the 4 bolt flange just a straight pipe setup....didn't need it for MA inspection due to the age.....but i have an idea of what I can do now......thanks guys!!!
post #6 of 6 Old 07-21-2009, 08:11 AM
USMC_JeepGuy
Mine doesn't look like that....anymore, I just cut it off last night, had to weld a patch where some idiot had welded the bracket to the pipe but it kept tearing a large hole everytime I went wheeling. Problem solved.
BTW, that idiot was me....
USMC_JeepGuy is offline
87 YJ 4.2 exhaust hanger missing motorman YJ Wrangler Technical Forum 1 09-19-2009 10:48 AM
Need a exhaust hanger andrewf09 YJ Wrangler Technical Forum 3 06-15-2009 07:32 PM
Exhaust hanger SteveJcoYJ YJ Wrangler Technical Forum 7 05-28-2009 06:22 PM
Exhaust hanger 3stripes TJ Wrangler Technical Forum 1 04-02-2007 12:25 PM
Exhaust Hanger Mount UltimatE YJ Wrangler Technical Forum 5 07-13-2005 06:47 AM
