Exhaust Fumes w/ Rear Window Removed - 1993 4.0 L6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Exhaust Fumes w/ Rear Window Removed - 1993 4.0 L6
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 03-19-2014, 07:44 PM   #1
Stingray427
Quick question:
I have stock exhaust setup with a turn down tailpipe exiting at the right rear of the vehicle (turn down faces downward and is pointing straight out rearwards) and I get a lot of fumes in the cabin with the rear window removed, any suggestions?
Thanks!
Stingray427 is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 07:54 PM   #2
superj
1987 YJ Wrangler
Run side pipes.
There is nothing you can do. The wind travels under the vehicle while driving and then comes up into the low pressure area created by the big square forcing itself through the air. You can try routing the exhaust differently or getting a bikini top so air is going around the sides and pushing the fumes away but until your aerodynamics change, that low pressure zone behind the jeep will stay there and all higher pressure air will continue to move into it while moving.
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 07:54 PM   #3
XxoSPARKSoxX
Free Range Jeep
Fumes
My suggestion:
Put the window back in....
Problem solved..
All levity aside, it is very common.
Updraft from the large, flat back side of the vehicle pushes fumes right into the cabin.
Jeeps are certainly not famous for being very aerodynamic.
Unless you have the whole top off or have a bikini installed where a lot of fresh air can rush through and carry those fumes out, you are pretty well dealing with the same issue most of us jeepers (I think I can speak for many here) deal with regularly..
Good Luck!!
Sparky
Sparky
XxoSPARKSoxX is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 08:59 PM   #4
bpounds
bpounds's Avatar
Keeping the front windows open or removed should help to keep a front to rear draft going. As long as you are moving.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 09:15 PM   #5
Stingray427
Thanks to all for the very detailed answers!
What about dumping the exhaust in front of the rear axle? I have heard of this but don't know if it would help.
Unread 03-19-2014, 10:09 PM   #6
Longview
That is what i did, but i have not ran my jeep since i have done it, (Not street legal yet) But i have my drain plugs out and i feel like it will just drift into the cab that way.
Longview is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 10:36 PM   #7
Stingray427
Anyone else dropped the exhaust in front of the rear axle to help with fumes?
Unread 03-19-2014, 10:56 PM   #8
Reno72
Reno72's Avatar
Ya, not just a jeep issue. Any car with a rear window that can be opened will say do not run it that way. Heck we had an old Buick station wagon that had that warning. There is a low pressure zone behind any moving vehicle (that's how race cars get into another's drag ) so moving the tailpipe further forward won't stop fumes from coming in.
Reno72 is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 11:54 PM   #9
Stingray427
Thanks, has anyone else done this with their exhaust and did it help with the fumes?
Unread 03-19-2014, 11:58 PM   #10
NonRubicon
Watch the following video (skip to the 3:43 mark to get straight to the point):
The flat boxy rear end of the Jeep tends to cause turbulence which curls the airstream back into the cab. The only reasonable solution is to crack open the front windows or remove the side windows to allow some airflow to reduce the vortex effect.
Or you can go this route
NonRubicon is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 04:46 AM   #11
90DesertTanYJ
Running the exhaust out the side will help. Maybe not solve but will help. Make sure the end of the pipe clears the body by a couple of inches as well.
90DesertTanYJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 11:02 AM   #12
TheGanzman
The trouble with THIS (ask any Midyear Corvette owner with side exhaust) is that "at idle" (like at stop lights), the exhaust wafts into your open side window(s). Prolly the only REAL "answer" is to upgrade to OBD2 and a late model engine with FULL emissions and catalytic convertor; I'm guessing that you don't wanna go to THAT level of expense JUST to run w/o a rear window...
TheGanzman is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 11:10 AM   #13
JohnnyZJ
JohnnyZJ's Avatar
had this problem big time in the last YJ. when i finally took it in to teh shop i found out it had the CAT removed. hence it smelled so bad.
with the last TJ i had, (with a CAT) it wasn't as bad and the JK we had was a non issue.
the YJ i have now (CAT in place) is 100% better than the YJ without the CAT.
i tried everything. only thing that really worked (for me) was putting another CAT on it.
if you still have the CAT is it functioning? if it is, then gonna have to get used to teh smell lol
92 YJ ~ locked rollin' on 35s
05' WK Hemi limited ~ future plan?
14' GMC Terrain ~ wifes
13' GMC Sierra ~ 2.5" lift 33" toyos.
RIP 95 ZJ ~ 33s built/longarmed/locked/awesome Feb 2014 ZJOTM winner
JohnnyZJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 12:25 PM   #14
Stingray427
I just added a brand new cat to my exhaust a few months ago and your right the smell is less noticeable but still there.
Sounds like this is just one of those things about driving a Jeep that you learn to live with.
Unread 03-20-2014, 03:42 PM   #15
fishadventure
You learn to live with CO?! The exhaust smell is not the issue LOL
I remember when cats and no lead were new things- we all thought they stunk so bad! We were used to the non-catalyzed exhaust smell.
Now everybody is used to the catalyzed exhaust and they think non-emissions-equipped exhaust smells bad.
Either way carbon monoxide can kill you...OBD2, OBD1, or no cat whatsoever!
I still like to smell nitro racing fuel in an old muscle car
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is online now   Reply With Quote Quick reply to this message
