Exhaust fumes in rear window - JeepForum.com
post #1 of 16 Old 10-09-2012, 02:45 PM Thread Starter
GatorsUF
Has anyone found a good way to stop exhaust fumes from coming in the rear window?
I have a softop on my Jeep and since its parked under an oak tree at my house I usually leave the top up and just pull all the windows out. For some reason this causes a vacuum in the back windows where air comes in the back windows as I am moving forward. Along with this air is all the exhaust fumes from my tailpipe which is on the passenger side under the bumper.
I am tempted to try an make it go more out the side of the jeep than out the back and hopefully that would help.
I am not as bothered by it, but my wife rarely wants to ride in the Jeep because she says "I don't want to smell like gas".
Ideas?
Sarasota Jeep Club
GatorsUF is offline
post #2 of 16 Old 10-09-2012, 02:48 PM
mrmark
they all pull the exhaust back in, just like a PU, you would have to exhaust out the side I would think to eliminate it.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #3 of 16 Old 10-09-2012, 03:18 PM
TJEvans
If I keep the rear side windows in, while having the door tops off and rear window open, I'll smell the fumes. If the rear windows are out, it let's the air escape before reaching the front passenger cabin.
TJEvans is offline
post #4 of 16 Old 10-09-2012, 03:26 PM
mrmark
I drive with an extended top no doors or windows and was blowing oil out the back, it would leave a film of oil on my dash.
mrmark is offline
post #5 of 16 Old 10-09-2012, 03:41 PM
Old4X
1990 CJ7
Run a bikini top instead, or else have all the windows installed in the top. Half doors or door windows down will not pull exhaust in if everything else is in.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 16 Old 10-09-2012, 04:36 PM
seattle_yj
Also if your exhaust is piped strait out the back, sometimes the fumes get sucked up by the tire carrier and such. If you add a tip on the back to pipe the exaust down, it will help with this. I put a curve on the end of mine and pointed it out to blow the fumes that way. I test it out and it helps tons. I just have to weld it on and pretty it up.
seattle_yj is offline
post #7 of 16 Old 10-10-2012, 08:25 AM Thread Starter
GatorsUF
Yea the only issue with going out the side is if I just got to the edge of the body it will still be right behind my rear tire and I imagine will get caught in the vortex again. If I go out past the rear tire it would look ridiculous.
I thought about pointing it down, does that help? Or cut it off shorter then point down before the rear axle?
Sarasota Jeep Club
GatorsUF is offline
post #8 of 16 Old 10-10-2012, 10:46 AM
seattle_yj
Pointing it down helped in my case. You can buy a tip and just try it out like I did. I wouldn't cut it back behind the axle though, I think that would make it worse.
post #9 of 16 Old 10-10-2012, 11:22 AM
HAYSHAKER170
You could always use the stacks like the semi's do. Heck, I even see those on some duallies now. Just kidding, don't do that.
HAYSHAKER170 is offline
post #10 of 16 Old 10-15-2012, 01:01 PM Thread Starter
GatorsUF
So pointing it down makes it not get pulled in through the rear window? Or just helps a little?
Sarasota Jeep Club
GatorsUF is offline
post #11 of 16 Old 10-16-2012, 12:59 AM
seattle_yj
In my case it pretty much fixed the issue. I have just tested this but not permanently installed anything yet. Note I'm a hard top though, soft tops are less forgiving with keeping out fumes.
post #12 of 16 Old 04-23-2013, 02:29 AM
etienne389
[QUOTE=GatorsUF;14276355]Has anyone found a good way to stop exhaust fumes from coming in the rear window?
Ideas?[/hi, i am new here. how are you? did you solve the problem ? i have same problem and i wish to solve it too. best regards. thanks]
etienne389 is offline
post #13 of 16 Old 04-23-2013, 08:02 AM
HaskiE
HaskiE's Avatar
alot of the time, to stop the blow back, I'll leave the back window in, and take the sides out. makes for a more aerodynamic jeep IMO, and it keeps the exhaust out, while letting fresh air in
#theneverendingaxe
HaskiE is offline
post #14 of 16 Old 04-23-2013, 09:37 AM
Joe100
Exhaust Fumes
Hi! I had to have a new exhaust system put on my YJ the fellow putting it on put the exhaust tip bent a 90* on it to go out the side . he say's it gets the fumes away from the back window. At least I don't have the fumes coming through the floor. Joe100
Joe100 is offline
post #15 of 16 Old 04-23-2013, 09:39 PM
mrmark
Wrong spot damn phone
mrmark is offline
