which exhaust? - JeepForum.com
post #1 of 3 Old 09-27-2001, 10:27 AM Thread Starter
lostboy
which exhaust?
I'm changing the the 4.2 head to the 4.0 head in a '89 yj. Which exhaust will work with this application? is the Borla header worth the extra bucks? and which model would I order ?. I will need the o2 sensor port.
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #2 of 3 Old 09-27-2001, 12:25 PM
Nightclaw
I've not been exceptionally impressed with the build quality of Borla headers I've seen in the past. The header tubes seem a bit thin, and I'm leery of their welds. However, it's been a while, so maybe they've improved since I last experienced one...?
Personally, I have a Thorley header and I love it. The part number is 634Y for F.I. heads. If your 4.0 head is off a fuelie Jeep, it should bolt right on.
Both the Thorley and the Borla have CARB EO numbers, and thus both have the O2 bung.
Nightclaw is offline
post #3 of 3 Old 09-27-2001, 04:10 PM
hardoncj5
borlas work fine, but i believe custom made exhaust systems (by a specialist-important) can optimize the performance in the best way
hardoncj5 is offline
Exhaust bung/plug size for TJ->YJ exhaust swap? I8AHUMR TJ Wrangler Technical Forum 1 01-01-2010 05:01 PM
Exhaust Hanger, isolator on transmission 4.2 stock exhaust Chris Aunchman YJ Wrangler Technical Forum 5 07-21-2009 08:11 AM
exhaust leak between header and exhaust piping 03rubiconMG TJ Wrangler Technical Forum 7 06-11-2009 08:02 AM
Upgraded head, but changed Exhaust Manifold so how do I get an exhaust system now? jeepdude1987 YJ Wrangler Technical Forum 2 02-18-2009 11:54 PM
Stud that attaches exhaust manfold to exhaust pipe keithert TJ Wrangler Technical Forum 0 04-28-2007 10:47 PM
