Excessive coolant pressure???? - JeepForum.com
post #1 of 9 Old 10-23-2011, 08:09 AM Thread Starter
eeeep10
I seem to be running a really high coolant pressure in my 94???? Any ideas what this might be? Or what I need to check
eeeep10 is offline
post #2 of 9 Old 10-23-2011, 08:44 AM
rustyyj
1987 YJ Wrangler
what temp do you normaly run at? what do you mean by high pressure? the pressure is controlled by the radiator cap. with a stock cap the system will be at about 13-15 psi (it should be stamped into the top of the rad cap)
rustyyj is offline
post #3 of 9 Old 10-23-2011, 09:01 AM Thread Starter
eeeep10
It's running around 190 to 200 usually. It started leaking out the bottom of the radiator and started to weap out of the cap and top hose
eeeep10 is offline
post #4 of 9 Old 10-23-2011, 09:05 AM
rustyyj
1987 YJ Wrangler
if all that happened while running at 190-210 id spend the $4 and grab a new rad cap of correct pressure (have your parts guy look it up) its the ceap easy place to start...
rustyyj is offline
post #5 of 9 Old 10-23-2011, 09:10 AM
johnny27030
When you replace the cap make sure to clean out any debri where the cap seals off. If there is grit in there it could cause the cap not to releive pressure like it should. If this doesnt fix it then try flushing the system.....even though if you temp gauge is correct it should not need. Hopfully you dont have a blown head gasket. Has it overheated recently?
johnny27030 is offline
post #6 of 9 Old 10-23-2011, 10:22 AM
dodger889
Remove radiator cap when cool start your engine let it warmup and look for air bubbles in the radiator. If found, you have a head gasket leaking.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #7 of 9 Old 10-24-2011, 08:38 AM Thread Starter
eeeep10
Ended up finding a small pin hole in the radiator, patched it up for now as a quick fix til i can replace it next weekend. After replacing it and driving it last night there was a pretty high pitch whistling sound. I'm not sure if it was the belt whistling bc it had gotten wet but I'll check it today
eeeep10 is offline
post #8 of 9 Old 10-24-2011, 07:02 PM
nembudonna
Why would a pin hole in the radiator cause high pressure in the radiator? The pin hole may have been caused by high pressure.
nembudonna is offline
post #9 of 9 Old 10-24-2011, 11:51 PM
nembudonna
If your going to replace your radiator, I'll pay the shipping if you'll send me the one with the pin hole.
Low oil pressure, and using coolant...4.0 steelmillman TJ Wrangler Technical Forum 5 03-25-2011 05:59 AM
Psssssssst......Excessive Fuel Pressure tallcan_ry YJ Wrangler Technical Forum 3 07-29-2009 06:45 PM
Oil filler cap leak/pcv excessive pressure fix mxmike211 YJ Wrangler Technical Forum 2 06-22-2009 11:23 AM
Excessive Valve Cover Pressure?? Bluevee33 YJ Wrangler Technical Forum 4 03-01-2008 03:48 PM
Coolant pressure F1973 YJ Wrangler Technical Forum 13 05-12-2003 05:44 AM
