-   -   Ex Islander Diesel Build (http://www.jeepforum.com/forum/f12/ex-islander-diesel-build-1401795/)
Homebrewed2 08-05-2012 05:00 PM
5 Attachment(s)
Hello! This is my first thread so please be kind.
This is my first build, it might take a while. I am getting married at the end of September so my funds are limited. I bought the Jeep from a friend who drove it through college. After I bought it it sat at my dads house from 3 years since I moved 3 yours away and didnt have a garage. After buying a house I hauled it down and it sat it my garage for 2 years. I finally built a shop and have room to work on it.
The drive train was completely stock 4.2, ba10, np231. The 4.2 was using oil and down on power. I pulled the 4.2 out planing on swapping in a 4.0 with fuel injection. Once it was running I was going to pull it and make a 4.6 stroker.
I picked up a Cummins 3.3l 4 cylinder diesel at work a couple of years ago that needed rebuilt. It is rated at 65hp, 185lb-ft of torque I think. It is/was naturally asperated. From the factory the turbo charged version put out 85-105hp. I plan on putting on a turbo, intercooler and bigger injectors, it should put it around 110-120hp, 300-350 lb-ft of torque. Most guys are getting 25-30 mpgs with this set up.
My Plans
nv3550
np231
Ford 8.8 regeared to 3.55 or 3.73 havent decided
Get rid of cad, have new axle shaft
Tj flares
4" lift
33X10.50
CJ Grill-done
CJ Dash
As she sits
Attachment 447233
4.2
Attachment 447214
4.0 new header
Attachment 447215
4.0 sitting in it
Attachment 447216
Cummins 3.3
Attachment 447217
There have been others that have done this swap before. Here are some good links
http://www.dieseltruckresource.com/d...j-t112807.html
http://www.jeepforum.com/forum/f22/l...-bean-1290765/
Homebrewed2 08-05-2012 05:06 PM
I cant spell, can you go back in and edit the post?
aaron580 08-05-2012 05:11 PM
Can't wait to see your progress. Make sure to take pics of the motor mounts you make for the cummins. I'm gonna do the same swap with a 3.9 next June when I have time. I've never seen a 3550 bolted to one before. Make sure your torque output isn't more than the tranny can handle.
UltimatE 08-05-2012 05:11 PM
You can click the little edit button on the bottom right of your post.
Homebrewed2 08-05-2012 05:54 PM
My needs
7 Attachment(s)
The 3.3l is different than they 3.9l. the 3.9 is a 5.9 block minus 2 cylinders, the accessories and motor mounts from a 5.9 should work. These 3.3 are used in a off road equipment, skid loaders, wood chippers stuff like that. They come with a alternator and no other accessories. I want to run air conditioning and an a Izusu npr alternator with vaccum pump for the brakes and heater controls. I will post pics shortly.
Sorry my post might be kind of random, I am trying to show everything I hae done so far.
I was never a fan of the square heads light, sorry:D. I looked into swapping the whole grill from a cj or tj but I didnt want to swap the hood and fenders also. So here is my solution, it still needs a
Attachment 447251
Attachment 447256
Attachment 447257
Attachment 447259
Attachment 447262
Attachment 447263
Attachment 447264
I will try and post more tomorrow.
imstillatwork 08-05-2012 06:26 PM
Square to round is like a sex change. It just ain't right! Enjoy what you have! lol-just messin'
Homebrewed2 08-05-2012 07:30 PM
Can you change the title on the thread?
NH2112 08-05-2012 08:54 PM
Looks pretty good! I'll take a diesel over a gasser any day - and not just because I can get a lot of waste Jet-A from work. :D I actually have plans to swap in a Nissan SD33T, most likely with a 3550 as well. The plan as of now is to run a hydroboost instead of vacuum boosted brakes. My goal is a Jeep that needs/has no electronics whatsoever to run. There aren't a whole lot of diesels that weigh in at close to a 4.2l, so heavier springs may be necessary. Plus they're often pretty tall, especially the ones with deep skirt blocks, so a suspension lift or some major sheet metal work on the oil pan may be necessary. Hopefully I won't have to doghouse the firewall.
Homebrewed2 08-06-2012 05:44 PM
The good, the bad, the ugly
7 Attachment(s)
My has the typical rot on the passengers side between the door and rear wheel. If yours doesnt have it consider yourself lucky. i replaced mine but it was a pain in the a@@. Here are some pics of it and my fuel filler swap also. I needed a bigger filler neck for the diesel so I robbed one off of a 1976 k20. With a litle straightening I think it will work.
I think I am going to try and find a tj plate holder.
Attachment 447914
Attachment 447914
Attachment 447921
Attachment 447922
Attachment 447933
Attachment 447934
Attachment 447935
pasinbuy 08-06-2012 05:57 PM
First off try logging on using Google Chrome. It is a much faster engine and in this forum spell check is automatic.
Second, Dude you are the man. I have been thinking for a while now. "Why don't I see more diesels in Yjs?"
If you hit water as long as you have a snorkel the diesel will motivate right through. The diesel also has
much more torque to move the Yj through anything, including big rocks. As I see it. In a diesel your battery
can float away and you can still move as long as you do not stall her. I love it!
I will be following your thread! You can bet on it. Good building.
tdij 08-07-2012 12:48 PM
Sub'd for a nice diesel build.
I like the square lights... but that is a nice idea with the grill. Look forward to seeing that completed and on the jeep.
The 3.3 is a great choice for a YJ. Keep up the build thread! :cheers2:
Homebrewed2 08-09-2012 06:50 PM
Diesel engine
9 Attachment(s)
Is there any way to change the title on the thread? Sometimes I am dyslexic.
Here are some shot of the mods I did to make the engine work for me. I wanted to keep the a/c compressor and power steering pump. I have read there is a a/c compressor mount made for these in some piece of equipment but I have never found pictures of it. Looking at some other builds people have used a alternator from an Isuzu npr that has a vaccum pump built into the back of it. The only downside is the alternator is rated for 70 amps only. I hope the vaccum pump has enough to run my brakes. I also wanted to keep the serpentine belt set up.
I took a water pump pulley from a 5.9 and cut the hub out of it.
Attachment 449875
Turned down the crankshaft pulley so it would slide over it.
Attachment 449876
Attachment 449877
I needed some place to bolt on some idlers and a belt tensioner. Here is my first attempt. The front gear cover already had threaded boss I bolted it to.
Attachment 449883
The alternator used to mount on this bracket. I flipped it over and welded a piece on to it the ran a bolt through it to mount my a/c compressor.
Attachment 449885
On the top I made a brace for it.
Attachment 449886
I bolted the alternator to the bottom of the a/c compressor and I will bolt it to the plate I made for the front of the engine.
Attachment 449893
For the power steering pump I removed the fuel filter and made a plate to bolt on the power steering pump I had from a 98 cherokee.
Attachment 449864
Attachment 449867
Attachment 449868
Attachment 449869
I need another idler pulley and a belt tensioner but here is how it is going to go.
Attachment 449870
Hopefully I got my measurement close and the belt will stay on. :highfive:
ashland82391 08-09-2012 07:01 PM
heck yeah this is going to be awesome! Dont get discouraged from posting from some of the other members, im looking forward to the finished product!:2thumbsup:
calpbs 08-09-2012 08:07 PM
This is an awesome conversion. I love the custom work.
jamesmc 08-10-2012 09:15 AM
@Homebrewed2 Keep at it. Great pictures and great idea/approach. :cool:
The time now is 06:00 PM.
