Everything you need to know about removing track bars or swaybar
#16 | |
It might be possible to do it for a while without incidence, but it's not very safe...
/l ,[___], l--L-⌐°lllllll°- ▒)¯ ▒)--♂-▒) |
#17 |
the springs hold you side to side on leaf spring setups so you tecnically dont need them. cjs came stock with out them. take them off and drive it and if you feel comfortable with it that way leave it, if not you can always bolt them back on later. I've been running with no sway bar/ track bars for 3 years now and it rides much better and i'm on the highway alot unfortunatly but its fine and i like the ride quality better without them.
#18 | |||
We have 2 lifted YJ's, both without track bars & sway bars, with no negative issues at all. Quote:
93jeepyj has it right, take them off, try it out, and only put back on the items that you feel that you need to make yourself comfortable. The sky is not falling.
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#19 |
thank you ill try it out this week end see how i like it or not
owers of: 91 jeep wrangler sport 2.5L 4" rough country lift, 3 inch body lift, 35x14-15 ground hog tires, smittybilt XRC-8 winch, dana 30 front, ford 8.8 rear welded |
#20 |
My 4.5 RE lift specifically tells you to dump the rear track bar. On a leaf spring vehicle they have little to no use. If fact I would guess 90% of leaf spring trucks don't have one from the factory
It Wouldn't Be A Project If Everything Worked Right. |
#21 | |
Do you have any idea how long they have been producing and selling leaf sprung vehicles without trac bars. As said earlier, the leaf springs locate the axle in all three planes just fine.
89 Jeep YJ Wrangler Weber Carburetor Aussie Front 4" Rough Country lift 33x13.50x15 tsl's on 10" steel wheels Red Jeep Club #448 |
#22 | |
Free clues & suggestions
![]() Somebody has either been feeding you some serious bull, or you don't have a complete understanding of how leaf spring suspension systems operate. Or.....more than likely, both. Both of my tracbars/panhard bars, the front swaybar and it's links, and also the steering stabilizer have been completely removed for ~11 years on my POS YJ with zero ill effects. You, or somebody else can buy mine if you wish - but I'll first have to clean off alot of dust & take then out of my trash can. ![]() ![]() ![]() Sometimes, when I'm feeling deeply ill, I miss my poor old tracbars & swaybar. Whenever I do, I simply pull them from the depths of my blue trash can & place them on a silver platter and toss them a little beer party. ![]() |
#23 | |
Been running with no track bar since I lifted my YJ |
#24 |
Just removed the rear track bar last weekend. The ride has been vastly improved. The best thing I've done to the old heep lately!!
If you're worried about it do a search, there's a wealth of info on this site about it. BTW, where in the Peoples Republic of NJ are you from? Last edited by vmann7; 09-02-2008 at 08:13 PM.. Reason: addition |
#25 |
track bars?
i don't understand why they are there anyway..i own an older(1975) Chevy p/u with leaf springs and no track bar...they never had one...so what was jeeps theory behind these things?
#26 |
Joe you pull that out every chance you can don't you?
#27 |
Another vote for NO Track bars.
I've been running no track bars (front or rear) for over a year now - no problems.
1992 YJ -2.5 Old Man Emu lift, RC 1-1/4" Boom greasable shackles, JKS Discos, 1" Daystar BL, 33x12.5x15 BFG AT KO's mounted on 15x8 Cragar soft 8's, flush mounted tailights, SJFab front bumper, TKH Fab swingout tire carrier welded to a Dirtworx rear bumper, Tuffy stereo console, RC SS Extended brake lines, Home brew plate relocation bracket, Magnaflow Cat, Dynomax Cat back, No track bars front or rear 1997 XJ - 4.5 RC coils + extra OEM spring isolator(6.5" actual front), OME medium duty springs+OME extra leaf + Teraflex 1.5 shackles (6.5" actual in rear), OME Long travel shocks, OME SS, IRO Adj TB, IRO Adj LCA'S, IRO Adj Uppers, RC Control arm drop brackets, JKS Quicker Discos, SYE / XJ shaft, 33x12.5x15 BFG AT KO's on 15x8 Cragar soft 8's, RC SS extended Brake lines, Hella 500's 1996 ZJ - RE 2 inch BB w/shocks (rides like crap), OME SS, 31x10.5x15 General Grabber AT2's - SOLD |
#28 |
hmm i may just take them off tonight lol, iam down south near millville, alittle closer to dorchester iam about 3 minutes from the dorchester wawa
#29 |
Oh well, about as far as possible in NJ, I'm up in Union County. Good Luck,
#30 | |
Think of the trac bars as the belt on a pair of snug fitting pants that are also held up by suspenders. As long as the frame of your YJ isn't rotted out near the spring hangers, the trac bars aren't doing much but limiting flex. I ditched mine after I got it. I did install 2" BDS springs so I'm not on the tried stockers anymore. I left the swaybar with discos. I've been driving all summer with the swaybar disconnected. Last Sunday the wife and I took a 100mi joyride up along the Delaware from Port Jervis to Barryville. The YJ rides as nice as the Grand Cherokee even thru the Hawks Nest section. Trac bars are easy to reinstall if you don't like it. I doubt anyone can tell if the rear one is gone just by driving. Unless the rattle is gone from the worn out bushings on the old trac bar. ![]()
89' YJ Larado 4.0L,AX15 01' Grand Cherokee 4.0L Check my Gallery for pics. My Rebuild Thread Take a minute and fill out your profile, Please |
| Tags |
| handling, lift kit, sway bar, track bar, trackbar |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
