Everything Jamesx4 has done for OBA. - Page 3 - JeepForum.com
post #31 of 103 Old 11-27-2007, 10:19 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
Originally Posted by jamesx2
Any idea what the flow rate would be compared to 1/4 inch ports?
How long would it take to fill a 31" tire?
Is it possible to tap the ports out to 1/4 or just go with a different tank?
Thanks
you could probably redrill and tap then for 1/4 fittings, but unless you already have the tank it would just be easier to get one with the fittings already sized where you need them.
try these guys, some of the best prices i've found for new tanks:
http://www.truckspring.com/firestone...tank-9229.html
not as many ports but that's easily fixed with some black pipe T fittings and some close nipples
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #32 of 103 Old 11-27-2007, 11:56 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
you cant beat this deal...
http://cgi.ebay.com/ebaymotors/AIR-T...spagenameZWDVW
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #33 of 103 Old 11-27-2007, 12:11 PM
bamato
bamato's Avatar
It is a good deal for 3 gallons! But eeewww..... its so shiny....
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #34 of 103 Old 11-27-2007, 12:13 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
and light. (aluminum)
post #35 of 103 Old 11-27-2007, 12:25 PM
sentinal02
sentinal02's Avatar
just be sure to contact them and ask them what the working pressure of the tank is before you buy. should be ok since they're telling you its for an air suspension, but i would want to know up front before hand
post #36 of 103 Old 11-27-2007, 12:33 PM
sentinal02
sentinal02's Avatar
actually after you calculate shipping the one i posted is cheaper. only 11 and change to ship to NY vs 15
post #37 of 103 Old 11-27-2007, 01:08 PM Thread Starter
YJames90
YJames90's Avatar
I bought this 2.5 tank
http://www.quadratec.com/products/92043_101.htm
My 2.5 to 4.3 swap thread
YJames90 is offline
post #38 of 103 Old 11-27-2007, 01:47 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
cheaper, but heavier, and with less ports.
i have the one i linked in my jeep.
i keep it at 125# with the york, and it likes it
i'm not pushing this tank on anyone, just posting up options.
every ounce counts, and in this particular case, you save ounces, gain strength, and bling factor as well as usable ports.
post #39 of 103 Old 11-27-2007, 02:10 PM Thread Starter
YJames90
YJames90's Avatar
pressure switch from factory AC
Can I use it for my OBA
YJames90 is offline
post #40 of 103 Old 11-27-2007, 02:32 PM
mp3coupe
mp3coupe's Avatar
I'm going to say no. First I don't know what the factory setting is on the switch. I do know the switch works opposite. If the pressure is correct you would need to wire up a relay so it works the correct way. AC pressure switch opens when low to no pressure. OBA switch opens when the pressure gets to X amount
mp3coupe is offline
post #41 of 103 Old 11-27-2007, 03:18 PM Thread Starter
YJames90
YJames90's Avatar
I didnt think it would be that easy to use the existing wireing and switch.
Thanks
YJames90 is offline
post #42 of 103 Old 11-27-2007, 03:41 PM Thread Starter
YJames90
YJames90's Avatar
the OBA parts are gathered
Here are my options
85 PSI on, 105 PSI off
90 PSI on, 120 PSI off
110 PSI on, 145 PSI off
165 PSI on, 200 PSI off
Is the 145 off pushing the envelope on a 150 tank?
YJames90 is offline
post #43 of 103 Old 11-27-2007, 03:42 PM Thread Starter
YJames90
YJames90's Avatar
Tolerance is 5% of specified pressures
YJames90 is offline
post #44 of 103 Old 11-27-2007, 04:31 PM Thread Starter
YJames90
YJames90's Avatar
Well, after more searching this is what VIAIR sells with their 2.5 tank
Kit Contains:
(1) 2.5 Gallon Viair Air Tank
(1) 450C model Viair Air Compressor
(1) 35ft. Coil Hose
(1) 1/4" Quick Connect Stud (F)
(1) 1/4" NPT Quick Connect Coupler (F)
(1) Dash Panel Gauge with ON/OFF Switch
(1) Pressure Switch with Relay (110 PSI on, 150 PSI off)
(1) Reducer (1/8" NPT F to 1/4" NPT M)
(1) 1/4" NPT 175 PSI Safety Valve
(1) 1/4" Drain ****
(3) 1/4" NPT Compression Fittings
(1) 4-inch Strip of Continuous Grommet Material
(1) 20ft. 12 Gauge Wire with Inline Fuse Holder
YJames90 is offline
post #45 of 103 Old 11-27-2007, 04:33 PM Thread Starter
YJames90
YJames90's Avatar
Ive been cencored!!!!
YJames90 is offline
