Everything Jamesx4 has done for OBA. - Page 2 - JeepForum.com
post #16 of 103 Old 11-21-2007, 07:03 PM Thread Starter
YJames90
YJames90's Avatar
Ok, so its go with the OBA set up with the factory a/c compresor.
Its just going to cost more than I thought, I was at home Depot today pricing needed parts.
i should have it done by spring time.
I removed the factory jack today to make space for the oba and re attatched the stock hoses, the intake hose can be reused by cutting off one end and adding an oiler and a filter
The output stock line can also be reused as I have read here that the hose gets hot so factory would be the way to go, it already has the correct fittings to the pump.
Im trying to go low budget as possible
My 2.5 to 4.3 swap thread
YJames90 is offline
post #17 of 103 Old 11-22-2007, 06:51 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
not sure if it's the same as yours but i used 3/4" npt fittings to thread directly to my a/c compressor.... i didn't use stock lines. and the black iron at home depot is much cheaper than solid brass
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #18 of 103 Old 11-22-2007, 07:22 AM Thread Starter
YJames90
YJames90's Avatar
Heres a basic setup that I found on the web.
no tank.It looks good for reairing tires.What do you think?
YJames90 is offline
post #19 of 103 Old 11-22-2007, 09:15 AM
joe's_yj
joe's_yj's Avatar
make sure you have oiler and moisture trap
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #20 of 103 Old 11-22-2007, 09:24 PM
ghost183
those capped ports arent ports, they are the fill and bleed taps of the threaded lines, the black capped one is used to fill the AC system with freon, an the red capped is the high pressure "service" port, some AC system dont have those fittings on the hoses as others do, i.e... my 92 YJ has them on the lines and not on the compressor, but a friends OOOOOOOOLD CJ has it in the compressor just like the one you have pictured, as far as specs on that compressor... cant help you there
hope this helps
ghost183 is offline
post #21 of 103 Old 11-23-2007, 07:42 AM
TSEJEEPERS
That is a Sandem compressor. You only use the ports that are uncapped in the first picture.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #22 of 103 Old 11-26-2007, 05:46 PM Thread Starter
YJames90
YJames90's Avatar
the OBA parts are gathered
Specifications
Capacity - 1.5 Gallons
Ports - (4) 1/8" FPT
Pressure Switch - 130 PSI on 150 PSI off
Dimensions - 19.25"L x 5"W x 6"H
Also Includes - Air Pressure Gauge, 2 compression fittings for 1/4" air line
Thanks, Im shopping around
YJames90 is offline
post #23 of 103 Old 11-26-2007, 05:59 PM
red87yj
red87yj's Avatar
1987 YJ Wrangler
i used two 5 gal tanks mounted on the fenders in the rear. i did this so that if i had to, i could turn the jeep off and still have pressure. any tank will work, thats the bottom line, if you can hold air in it and it has a place to mount a manifold, it will work. worry about where you will mount it and that will be the foundation of your decision. it is nice that this tank has a pressure switch on it. again anything will work.
Later
Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline
post #24 of 103 Old 11-26-2007, 06:18 PM
hogzilla
I personally wouldn't go any smaller than 1/4 " on all lines, fittings and ports.
3/8 " would be perfect.
'94 4.0 auto, Rubicon Express 4", 32x11.5 BFG AT, Herc'd, other stuff.....
hogzilla is offline
post #25 of 103 Old 11-26-2007, 09:30 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
x2. 1/8" fittings are really going to throttle back your air flow and you're probably be unhappy with the performance of the system overall.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #26 of 103 Old 11-27-2007, 02:32 AM Thread Starter
YJames90
YJames90's Avatar
Any idea what the flow rate would be compared to 1/4 inch ports?
How long would it take to fill a 31" tire?
Is it possible to tap the ports out to 1/4 or just go with a different tank?
Thanks
YJames90 is offline
post #27 of 103 Old 11-27-2007, 03:09 AM
swedishdwarf
swedishdwarf's Avatar
My gas physics is pretty rusty, but I think 1/2 the diameter=1/2 the area=1/2 the flow. I would shop for a tank with 3/8" outlets.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #28 of 103 Old 11-27-2007, 07:11 AM
red87yj
red87yj's Avatar
1987 YJ Wrangler
check out a store like harbor freight or tractor supply, get a cheap air tank and a regulator, work from there.
Later
Zach
3.5 BDS Lift
red87yj is offline
post #29 of 103 Old 11-27-2007, 07:14 AM
MTpockets
MTpockets's Avatar
its a mini truck site but ive gotten tanks for good prices when i had my s10 at suicidedoors.com
i would definatly go at least 3/8" ports
1997 TJ 5.5" long arm kit, 35x12.50 bfg m/t's, d44 front/rear 4.88 gears with arb lockers
ALWAYS ACCEPTING DONATIONS!!!
MTpockets is offline
post #30 of 103 Old 11-27-2007, 09:57 AM
bamato
bamato's Avatar
I'd also like to recommend 3/8" ports. Most pneumatic tools wont run on such a small air line (if you ever plan to use them).
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
