Everything Jamesx4 has done for OBA.
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
aka Jamesx2
I removed my stock under dash AC unit today in preperation for OBA.
Now the bigger hose that goes to the compresser is leaking a red fluid, not alot but enough to make a mess. Is this oil for the compressor and i cant let it run dry? the compresser end is still connected, I ran out of daylight Im searching for a link with pictures and instructions but cant find one yet. I was going to drive the jeep to work tomorrow but i guess its safer to plug the lines first. Thanks for helping
My 2.5 to 4.3 swap thread http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/ If your going to talk about me talk to me |
#2 |
Good luck with the OBA project. I'm definitely interested in doing one myself. My A/C is just sapping power from my engine right now, so I figure I might as well make use of it. Are you planning on incorporating an air tank? If so what size are you thinking? I just saw an air tank at Wal-Mart for like $20 that held I think 7.5 gallons, you think thats big enough to fill up tires, run air tools, etc? If you can take pictures I would really appreciate it. Good Luck!
1989 Wrangler Jasper Rebuilt 4.2L, Weber 32/36 carb, CJ7 front clip (Round headlights, hell yeah), 33x12.5x15 Wrangler MTR on 15x8 AR Baja wheels I need some things for my jeep, if you've got them used and cheap let me know: Rear axle 8.8 or D44, ANY transmission (stupid BA 10/5...grumble...), actually just about any part... |
#3 |
you should be okay driving to work today, there is a clutch on the compressor so the parts inside don't move unless you turn it on. you really don't need a tank to air up your tires, but your pressure switch will hate you. i had a small leak in a tire and used mine for months without a tank. the tank just really helps if you want to run tools but is also really nice airing up the tires. at idle i aired up my completely flat 33 up to 20psi in right around a minute with my tank. i got my tank for $40 on ebay and it is a 5 gallon. most people have 2.5 gallon tanks and i can see why once i got mine. it was a little hard finding a spot to mount a 6"x36" tank. definitely no room under the jeep for that, a 2.5 would have been perfect under there. i still need to remove my plenum and stuff inside but i'm taking my time because i will wait to sell it at the beginning of next summer.
http://community.webshots.com/user/richmond1273 1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears 3" Rough Country suspension 33x12.50 Mastercraft MT 2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears |
#4 |
Here is a pic of my oba...
Not an old air conditioning unit though. For an air tank I got a tank from an old Kenworth for running its air horns(it is like 2 gallons-16 long by 6 around, mounted under the battery tray). With a belt driven unit, you should not need a large tank. FYI-Your air conditioning pump will need a supply of lubracation oil, this lube is in the freon now... ![]() |
#5 |
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=2&sid=711ac7ac7199f3553464beeccd87 e701this thread has some helpful info.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000 |
#6 | |
H2 Recovery Team Member
MR, that tank won't do you much good without a way to fill it. air in a tank doesn't work like CO2. with a CO2 tank, the liquid CO2 acts as a much larger reserve to keep feeding the gas. with air you're limited by how much pressure you can put into the tank. then all you can do it distribute it across the tires evenly. and since most off road tires are substantially bigger than 7.5 gallons you won't be able to fill all 4 to where you want to. even if you estimate a tire on the conservative side at 20 gallons, that's still 80 gallons of space to fill. P1*V1 = P2*V2 so 125 psi *7.5 gallons = P2 * 87.5 gallons (remember the tank isn't going to be pushing air out one it reaches an equilibrium pressure so you have to include it in the volume of the second state). so you could fill up each tire a little less than 11 psi. and that's only if you're starting with no pressure in the tires. otherwise the last one will reach equilibrium before you hit that mark. it's just not worth taking up the space int he back of the jeep for only a small gain.
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#7 |
__________________ Ok that is all greek to me. He has a way of filling the tank you can see the pump front of the engine passenger side.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org |
#8 |
yeah but for filling tires with a belt driven compressor you don't really need a tank to begin with, it's just nice for a sudden boost of air.
Unlimited Length YJ "Sasquatch" Build Thread Renix 4.0 AW4 swap with awshifter = DONE custom console flatdash |
#9 |
No not really needed. Your compressor will not have to work near as hard with one. Also if you run a ARB the compressor will only run enough to fill up the tank. There will be more than enough air to run the ARB without the compressor having to kick on.
#10 | |
#11 |
aka Jamesx2
the OBA parts are gathered
What ports do I use and does anyone know what compresor this is?
Heres the 4 ports, the original caps are on and the 2 open ports are from the AC lines [IMG] [/IMG]Here they are uncapped, the 2 horizontal ports look like air line connectors [IMG] [/IMG]Heres the compressor from the front [IMG] [/IMG]Heres some markings on the face [IMG] [/IMG]Heres the wireing going to the ground and inside the jeep [IMG] [/IMG]
#12 |
aka Jamesx2
who can help before this thread gets pushed down to the second page?
#13 |
aka Jamesx2
Please help?
#14 |
aka Jamesx2
All in one charger and compressor
Ive had this sitting around for awhile and thought it was time to put it to good use
![]() I want to hard wire it in, it can be recharged with a cig lighter port I want to add a tank and set it up for oba Im thinking I can take apart the pump switch and wire in limit switch so the compressor turns off when the tank is full Im not sure of the inflation speed I want to mount this to the area where the factory jack was, this way I have a lite and the jumper cables will reach the battery Heres the specs SPECIFICATIONS: Model: VECO12POB Battery Charge Level Push-button - LED Indicator Lights Show the Charge State 12 Volt DC Output Socket with Automatic Short Circuit Protection Recharging Port – Includes a 110V wall charger Rugged weather-proof ~ Unbreakable Housing Heavy-Duty 450 Amp Battery Clamps - Extra Long 22” Heavy-Duty Welders Type Cables USB Charging Port Built-in Emergency Area Light ON/OFF Power Switch Charging Battery Status Indicators (LED display shows full charge or battery level) Lighted Pressure Gauge Air Compressor On/OFF Switch Contains sealed non-spillable lead acid battery. Must he replaced or disposed of properly. 15” Air Compressor Hose WARNINGS: The inflator is capable of Inflating up to 260 pounds per square inch To avoid over-inflation, carefully follow instructions on articles to be inflated. Never exceed recommended pressures - Bursting articles can cause serious injury. Always check pressure with pressure gauge. Never leave the inflator unattended while in use. TWO YEAR LIMITED WARRANTY PROGRAM Perfect for: Emergencies Camping Boating Lawn/Farm Equipment Traveling Tow trucks, service stations Perfect for Remote Areas College Students Older Vehicles Package Includes: Jumpstart-System with 260 PSI Air Compressor Instantaneous Cranking Power 450 Amps Continuous Cranking 300 Amps Battery - 12 Volt 19AH/20HR Sealed & Rechargeable 120 volt AC/DC adapter/power cord for recharging from standard wall socket 12 Volt DC/DC power cord for charging from vehicle
#15 |
BUILT. NOT BOUGHT.
save yoruself the time and agrevation... that pump is by no means capable of running OBA.... and the charger would be pretty useless...
that thing is best suited as a tool that takes up valuable storage space and is hardly ever needed... nothing more...
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
