Ever used propane to start a flooded Jeep? - JeepForum.com
post #1 of 4 Old 02-17-2007, 02:15 PM Thread Starter
NEPhillyJeep
NEPhillyJeep's Avatar
Me and a buddy ran down to the Outer Banks to go play in the sand and run the off road trail down there in Corolla. We were having a good time of it and started down a trial that had a few water holes and such. Well I was in the lead and came into this rather modest water hole and before I knew it I was swamped. I mean I went from water just at the axles to water bout over the front of the hood. She ran for a little while as I tried to rock her backwards to get out and until then it was going good then she ingested too much water. Long story short Brian got me out, and we were pulled off my intake and of course there was water in it...D^amn it... We both didn't have any starter fluid, but I did have my torch with me, so I opened the value and let the gas go into the TBI and sure enough she started right up....What can I say but you just have to love a Jeep.
NEPhillyJeep is offline
post #2 of 4 Old 02-17-2007, 02:28 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
considering that all it takes is a tablespoon or two of water on top of your piston to cause major damage to the engine i would think about pulling the plugs before reaching for the torch next time you get swamped
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 4 Old 02-17-2007, 05:58 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
good to know! haha, never know when that torch may come in handy!
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 4 Old 02-17-2007, 06:19 PM
TellyDSP
Poland and PPV!!!!
Did you pull your plugs and clear the cylinders before cranking it over? Think I'd change all of your fluid too.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
Flooded Jeep - What to check/replace? SimonTuffGuy YJ Wrangler Technical Forum 25 11-17-2009 04:00 PM
YJ seems flooded....cant get it to start FrankieCarbone YJ Wrangler Technical Forum 8 12-28-2007 11:43 PM
I think I flooded my transmission Longfellow110 TJ Wrangler Technical Forum 4 11-11-2007 04:14 AM
Jeep is flooded?! jeep_chinto TJ Wrangler Technical Forum 19 10-25-2005 04:01 PM
OOPS... I flooded my YJ! Chris C YJ Wrangler Technical Forum 8 09-26-2001 08:20 AM
