estimate on oil leak - JeepForum.com
post #1 of 6 Old 05-16-2010, 03:37 PM Thread Starter
evilmanke
I've had an oil leak for some time now but it never seemed serious because it would happen when I'm not looking. But I finally got around to degreasing and finding the source, which is that rubber piece near the oil filter. My dad said i might have to replace the whole part but I'm double checking with you jeep experts to see other options.
Close up of the leak.
http://i63.photobucket.com/albums/h1...e/113_0029.jpg
Part in relation to the oil filter.
http://i63.photobucket.com/albums/h1...e/113_0030.jpg
evilmanke is offline
post #2 of 6 Old 05-17-2010, 09:51 AM
Mugzz819
I believe thats the oil pressure sending unit. If you search that on the forum you should get lots of info and pics to help you out.
Mugzz819 is offline
post #3 of 6 Old 05-17-2010, 09:53 AM
Louie4
That is indeed the oil pressure sending unit as stated above. Must have sprung a leak internally. You can get a replacement at Autozone for $26 or so.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 6 Old 05-17-2010, 10:09 AM
moonshinefuel
The pressure sending units at Autozone I bought were garbage. One lasted less than 10k miles, others not much better. Went through 3 in a couple of years. I just recently put a mechanical gauge in. Leaking oil can destroy an engine if you loose enough obviously, and when my sending units would start leaking, they would leak more than just a few drops at a time, it was more of a steady stream when mine went bad. Luckily I did not loose an engine with those pieces of garbage.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 6 Old 05-17-2010, 11:41 AM
Louie4
I replaced mine maybe 5-6 years ago and haven't had a problem since. Maybe you got a bad batch or something. I agree that a mechanical gauge is a lot better.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 6 Old 05-17-2010, 06:39 PM Thread Starter
evilmanke
Thanks for the input, I think I'll settle with buying the part from autozone and putting it in myself.
Did any mechanical gauge work or did you order a special one?
Gas milage estimate... Thisisaustin JK Wrangler Technical Forum 26 09-23-2009 02:02 PM
Jeep estimate? lone_ranger YJ Wrangler Technical Forum 2 01-20-2007 08:21 AM
Help me estimate the value of this one. JoshBowers TJ Wrangler Technical Forum 4 08-09-2006 07:15 PM
*Got an estimate* wow!! twinjeep97 TJ Wrangler Technical Forum 48 08-01-2006 09:28 PM
How much you estimate this repair? Black87 YJ Wrangler Technical Forum 24 03-21-2005 03:58 PM
