error codes help - JeepForum.com
post #1 of 3 Old 05-04-2011, 03:04 PM Thread Starter
ryguy8686
error codes help
so my computer fried on my 94 yj..ok well flamed would be a better description..so i had the computer, alternator, wiring harness, cam sensor, crank sensor and the coil all replaced. some by me some by mechanics. when i got it home it started up and i drove it off the trailer. it sat all winter. i went out a couple months ago and started it up. started fine first couple times, then stopped. so now it has no spark and low fuel pressure. i checked the error codes on got:
12 direct battery input
33 open/shorted a/c clutch relay
54 no fuel sync detected
42 open/shorted auto shutdown relay
I know i need a new fuel pump, no problem there. and from what i gather the error 12 will always be there. as for the other three..i have no idea how to fix at this time. i have been looking around but just havent found the answers i am looking for. could someone help and give me straight forward ideas.
Thanks
ryguy8686 is offline
post #2 of 3 Old 05-04-2011, 04:43 PM
bigbossd1030
Thanks
Ok so,
33 means you don't have an air conditioner installed (not a concern)
54 means your fuel pump is shot
42 your auto shutdown relay is shot, its under the hood in the relay box, I think.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 3 Old 05-04-2011, 07:19 PM
dodger889
54 is the cam position sensor is acting up or crank position sensor is not working. Which could be just unplugging and reconnecting them back those two sensor might fix your problem there.
for 42 could be basically remove and reinstall the relay might correct that too. if not replace it with the horn relay see if the problem goes away (bad relay)
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 06:05 PM
Error codes sparkdr220 JK Wrangler Technical Forum 2 11-10-2007 11:29 PM
Error Codes slowTJ88 TJ Wrangler Technical Forum 2 04-08-2007 06:07 PM
My error codes - need help! BChamberlin TJ Wrangler Technical Forum 15 12-06-2006 02:38 PM
error codes rattletrap YJ Wrangler Technical Forum 5 09-08-2005 02:07 PM
