Error Code translation? - JeepForum.com
post #1 of 8 Old 08-06-2011, 04:15 PM Thread Starter
Anghil
I've had my '95 YJ for about a year and a half now and recently my "check engine" light came on. I tried using the manual to decrypt the code and I've tried using my neighbors vehicle knowledge, but I'm still at a loss as to what is wrong with the car. Here's a video of the code(s), can somebody help me translate this? Thanks!
Anghil is offline
post #2 of 8 Old 08-06-2011, 05:08 PM
Getdirtyoffroad
Here ya go...http://getdirtyoffroad.com/code.htm
Getdirtyoffroad.com
Getdirtyoffroad is offline
post #3 of 8 Old 08-06-2011, 05:33 PM Thread Starter
Anghil
Thanks! But that's the part I've got. The problem I'm having is understanding what codes are being displayed.
Anghil is offline
post #4 of 8 Old 08-06-2011, 06:06 PM
Alfons
When you count the flashes, there will be a short gap between the digits relating to the same number (example "flash", short gap, "flash", "flash" relates to 12), then there's a larger gap before the next number starts flashing until you get to 55 and then it's all over.
From what I see, the codes are 12, 33, 21, and 55. The first and last are almost always there, code 33 tells you that you have a problem with your a/c clutch & if you don't have a/c, it will always be there. Finally, the code 21 is telling you that the ECU isn't really communicating with the oxygen sensor.
Alfons is offline
post #5 of 8 Old 08-06-2011, 07:33 PM Thread Starter
Anghil
Thanks, Alfons! Guess I'll be replacing my O2 sensor! Also, thank you for the explanation of how to read the code.
Anghil is offline
post #6 of 8 Old 08-07-2011, 07:29 AM
Alfons
Good luck, old oxygen sensors often seize into their threaded hole in the exhaust-pipe. A good solid socket and some heat should get that out for you - if the sensor is seized into place, don't use things like adjustable or open end wrenches. They'll spread enough to round off the corners and then you have a much harder time removing them. When you're ready to install the new one, be careful not to get any oil or grease on the porcelain end, especially where it meets the threaded section. Also, when installing the new one, don't overtighten it - check out some "how to" videos on the internet, they'll explain all of this in much more detail.
Alfons is offline
post #7 of 8 Old 08-10-2011, 09:31 AM Thread Starter
Anghil
Thanks for your help! My new sensor is on it's way.
Anghil is offline
post #8 of 8 Old 08-13-2011, 11:13 AM Thread Starter
Anghil
On and done! Goodbye error code 21!
Anghil is offline
Code Translation tavic TJ Wrangler Technical Forum 3 12-04-2009 03:13 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
Error Code 25 BringThaPain TJ Wrangler Technical Forum 4 12-01-2008 08:57 PM
Help, error code 300 Existence TJ Wrangler Technical Forum 1 08-20-2006 01:48 PM
Error code help TJdave TJ Wrangler Technical Forum 11 08-18-2006 12:30 AM
