Error Code Help - JeepForum.com
post #1 of 6 Old 05-02-2013, 09:29 PM Thread Starter
0verkillYJ
Error Code Help
I have an occasional low idle and error codes 51, 21, & 14. Anyone know what would cause all three of these error codes at the same time? Jeep is driving fine. No loss of power or anything. Just 1 in ever 10 times I stop or so id idles down around 600 rms. I would replace the MAP sensor, but sine I have the two other codes at the same time I am not sure if something else may be to blame.
95 YJ, 2.5 AX15 conversion, 4.0 TB, SOA +1.5", 33" DC Crusher Tires, 8.8 Rear w/welded tubes + LSD, Spartan Locker HP30 Front w/solid axle swap, Rocky Road OTT kit, JKS Disconnects, AA SYE, Teraflex Shock Bar in Rear, 1/2" Boomerang Shackles, RE Add a Leafs, Homebrew Traction Bar, Monstalined in&out, LED Tail lights, 1700 Watt Stereo
0verkillYJ is offline
post #2 of 6 Old 05-02-2013, 10:38 PM
bigbossd1030
51 is the air to fuel mixture is wrong and 21 is the o2 sensor. And 14 as you know is the map sensor. Change your o2 sensor and reset toe computer. Drive it for a while and see if it changes at all.
Edit: 51 is a lean mixture.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 6 Old 05-03-2013, 08:19 AM Thread Starter
0verkillYJ
Yeah, I know what the codes are. My O2 sensor has less than 5k miles on it. I replaced it last year. I wasnt sure if a clogged injector could cause this. I figure it could cause the lean conditions, but am confused about the MAP sensor code.
51 O2S signal stays below center (lean)
21 O2S stays at center or O2S shorted to voltage
14 MAP sensor voltage too low or too high
post #4 of 6 Old 05-03-2013, 11:10 AM
Siva283
Swap your O2. They go bad easily. Sometimes they last forever sometimes the die quick. For the Map code you NEED to check your vac lines for leaks. The smallest vac leak can wreak havoc on these engines.
Ask me how I know...
Siva283 is offline
post #5 of 6 Old 05-03-2013, 11:11 AM
Siva283
A Vac line I capped off caused mine to throw TPS codes. Fixed the line codes gone and engine runs great. You can spray carb cleaner by them and listen for an idle change. If the idle changes you have a leak there.
Siva283 is offline
post #6 of 6 Old 05-03-2013, 03:14 PM Thread Starter
0verkillYJ
You know I capped the line that went to the CAD recently. Didn't even think to check it. I thought I sealed it good, but maybe I should have done a better job. I will check that and also use some epoxy to seal it. That should fix it for good.
