Epic Ignition Battle (replaced everything but the ignition switch!) - JeepForum.com
post #1 of 11 Old 08-21-2009, 08:17 PM Thread Starter
thechadwick
Living the dream here in Sunny Phoenix AZ when midway through a rain storm I lost the ability to start my car without parking on a hill. Lights, Gauges, Stereo all fine but no activity when I go to turn the key to start. Found what appeared to be the source of the problem (Pos lead to starter had contacted the solenoid ground and shorted...) 1 refurbished starter later still no dice. Replaced the leads from the battery which had tested good thinking it was a bad ground or something to no avail. Take the battery in again and sure enough its bad. New battery plugged and ready still no dice. So now I'm thinking the rain and short must have catastrophically damaged the starter relay right? Nope, no go. Tested continuity on all the maxi fuses, all good but replaced the ign one for good measure. So now I'm down to behind the firewall I'm thinking is where my continuity problem lies, removed the ign switch and it doesn't smell burnt but looks different than the one specified in the haynes. Run down to the auto shop store and the one they have looks like the one in the picture but after opening and inspecting every single box of ign switches(thx checker cashier) I left empty handed and broken hearted that I'll ever start my Jeep by key again... I'm working on a 1994 YJ 2.5l with a manual trans. hoping somebody out there might know the magic words to bring her back to life. here's a couple pics of what I'm talking about. Thanks guys -Chad
-492D CA Bn, Phoenix AZ
thechadwick is offline
post #2 of 11 Old 08-26-2009, 09:51 PM Thread Starter
thechadwick
Two weeks now, still no luck finding out what type of ignition switch I've even got on my steering column. Looks like I'm not going to get much love from the dealership regarding a 15 year old vehicle.. sure happy to sell me a new one though (eyes roll)... Anyone have an idea? Maybe (please Lord) a guess at a part number?
post #3 of 11 Old 08-26-2009, 09:56 PM
wheresthebfh
1987 YJ Wrangler
if you does it turn over but not start or just nothing? Just asking cause theres not a lot of hills in phoenix. Have you tried pull a part or a craigslist wrangler being parted out?
Milk it does a body good........
wheresthebfh is offline
post #4 of 11 Old 08-26-2009, 10:06 PM Thread Starter
thechadwick
"theres not a lot of hills in phoenix." Ha you aren't kidding, kind of a pain actually. Haven't had time to run to a pick and pull, but that's a great idea. Know any ones worth recommending? Recently moved to mesa from Ft. Jackson, SC and I'm not real familiar with the area... Anyway, it'll run fine but when I turn the key I either get a solid clunk or solenoid chatter. tested the solenoid and it's ok by the Haynes electrical manual. With the thing driving though the gauges (speedo and tach) bounce around like somethings shorted. other than that all's normal. Thanks for the reply man -Chad
post #5 of 11 Old 08-26-2009, 10:40 PM Thread Starter
thechadwick
wow, Major Major moment... Pictured item = headlamp dimmer switch... ≠ign switch. very embarrassed. Relieved to know I don't have a one off steering column
post #6 of 11 Old 08-27-2009, 02:46 AM
timatoe
timatoe's Avatar
The actual ignition switch is on top of the column behing the dash held on there with a couple of 7mm bolts. There's a rod that runs down the column into the switch, that's activated by the key switch part. Make sure you get that rod back in the right place when you put the new switch on there.
timatoe is offline
post #7 of 11 Old 08-27-2009, 03:24 AM
HHippo
In Mesa there is a big "Pick-a-part" on Extension just south of Main. Several other smaller ones in the same hood.
The switch on the column is a garden variety GM type switch, but if the starter makes a clunk and the solenoid chatters when you turn the key to start, odds are the switch is fine. Should have a starter relay if it is like mine. Check that there is no voltage drop across the red and brown wires at the starter relay when attempting to crank (the yellow comes from the crank position at the switch and if you have battery voltage there when cranking the switch is fine). Be careful when checking this and make sure the vehicle is in neutral at all times as it can accidentally crank with the key off if you touch the red and brown wires.
Check battery voltage while charging and while attempting to crank, and do a voltage drop test on the pos and neg battery cables. If all that checks to spec it probably is in the starter.
HHippo is offline
post #8 of 11 Old 08-27-2009, 06:03 AM
drunkencitywork
sounds like what i went thru just to find out it my computer was bad
95yj2.5auto-4"sua-305/70bfg mt on rubi's-4.0tb-frnt tube fenders-frnt&rear fabbed bumps w tire swing-8.8lsd disc-shortened xj soon cage,rockers,diff covers
drunkencitywork is offline
post #9 of 11 Old 08-27-2009, 06:14 AM
Que89YJ
I got to ask. Did you try and jumper the starter relay. It seems you went strait for the switch and the relay is usually the weak point. I am a few minutes late with posting today. everyone is bearting me to the punch. HHippo did a great job of explaing it.
Que89YJ is offline
post #10 of 11 Old 08-27-2009, 08:26 PM
Smash209
Smash209's Avatar
Check to make sure the wire that goes from ign switch to starter solinoid is not intermittent. I had to run a new wire end to end as it has a few splices (threw firewall bulkhead connector etc.) which were causing an intermittent problem.
You could try just jumpering the starter terminals when it wont start to diagnose the problem as Que89YJ suggested.
Smash209 is offline
post #11 of 11 Old 08-27-2009, 11:02 PM
WCoon
WCoon's Avatar
Also try running a second wire from the pos terminal to the pos on the starter. I had some starting issues and I ended up running a second, 4ga wire to the starter since the original one wasn't flowing enough current. You could also check it with some jumper cables to see if it does anything for a quick check. Let us know what you find.
WCoon is offline
Replaced ignition now nothing happens aklsufan TJ Wrangler Technical Forum 0 01-21-2010 05:53 PM
94 YJ 4.0L ignition problems, I've replaced everything I can think of ltjblalo YJ Wrangler Technical Forum 10 04-21-2009 07:40 AM
No spark..replaced crankshaft sensor, ignition coil, distributor(rotor and cap) amsgwp YJ Wrangler Technical Forum 4 03-08-2009 09:16 PM
Replaced stereo and that annoying ignition buzzer isnt working? Roach YJ Wrangler Technical Forum 7 12-07-2005 01:58 PM
HELP!!! Replaced Ignition Module, won't run! bidnizman YJ Wrangler Technical Forum 5 10-12-2004 07:24 PM
