Engine will not start - JeepForum.com
post #1 of 8 Old 08-08-2012, 10:29 PM Thread Starter
YJ88GA
I just finished rebuilding my 258. I installed everything correctly(to the best of my knowledge), based on the pictures I took as I took the engine apart. I go to start it and it doesn't start, but it does crank. It sounds almost like the battery was dead, so I replaced it and I still get the same thing over and over again. Until late this afternoon I go to try and the muffler explodes!!! Don't know how this happens but I need help I have no clue why it wont start.
Already replaced the spark plugs, old distributor cap and wires though.
Any Ideas??
YJ88GA is offline
post #2 of 8 Old 08-09-2012, 05:40 AM
medicjz
Spark...pull a wire and check with plug
Fuel...fuel making it into the carb?
medicjz is offline
post #3 of 8 Old 08-09-2012, 06:57 AM
aleh17
Well I just had a similar problem with my 4 banger, it cranked correctly but didn't start and I also had a loud "ploc!" noise, almost like an explosion, turned out to be that I had the spark plug cables in the incorrect order, did you already check that on yours?
aleh17 is offline
post #4 of 8 Old 08-09-2012, 07:09 AM
Que89YJ
Dumping raw fuel into the exhaust it collected in the muffler and then a good spark is all it takes. You appently have good fuel so you need to check for spark and your timing.
Que89YJ is offline
post #5 of 8 Old 08-09-2012, 08:23 AM
srdart67
Check that you are for sure at top dead center on the compression stroke with the distributor rotor pointing to the #1 cylinder. Make sure you don't have the distributor 180 degrees off. I just got done with my 258 and spent 3 frustrating days until it hit me like a ton of bricks that I was 180 off.
replace your cap, rotor, wires, plugs and coil if you can that way you can rule out any issues with them if you arent getting the timing right.
It would be alot easier for one to determine what the issue could be if you gave more information on exactly what you did to rebuild the motor.
srdart67 is offline
post #6 of 8 Old 09-20-2012, 03:55 PM Thread Starter
YJ88GA
srdart67: I replaced all of the gaskets and replaced one of the pistons.
Thanks for all the advice! It ended up being the timing was off. But was wondering if I have to weld the new muffler on or could I just simply clamp it it into place (I don't know how to weld trying to do it all myself).
YJ88GA is offline
post #7 of 8 Old 09-20-2012, 04:00 PM
Que89YJ
Yes you can clamp a muffler.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 8 Old 09-22-2012, 03:45 PM Thread Starter
YJ88GA
Thanks!
YJ88GA is offline
258 inline 6 , 4.2 liter , muffler , wont start
My 97 TJ engine will not start kmoore24 TJ Wrangler Technical Forum 4 05-26-2010 01:10 PM
No ECL - Engine Won't Start hogelectra YJ Wrangler Technical Forum 2 03-06-2010 12:58 AM
Engine won't start. joesTJ TJ Wrangler Technical Forum 14 07-15-2009 05:16 PM
Help Can't Start the engine? wrangler53 TJ Wrangler Technical Forum 12 10-21-2003 09:31 PM
Engine got wet - won't start AlanH TJ Wrangler Technical Forum 4 09-22-2002 04:00 PM
