Engine whistle? Help 95 YJ 4cyl. - JeepForum.com
post #1 of 6 Old 01-20-2010, 09:53 PM Thread Starter
zhahn888
Hey guys. I recently swapped my 2.5 TB to a 4.0 TB and noticed a little difference.. The past few days as i would accelerate i noticed a small whistle coming from the engine. It comes and goes both getting louder and quiteter, but im down at school and worry about anything going wrong. Should i worry or could it be a gasket leak?
95 YJ 4 cyl./ 31x10.5 MTR/ Smittybilt SRC/ Hella 500FF Lights/ 4.0 TB/ Cherry Bomb Exhaust
zhahn888 is offline
post #2 of 6 Old 01-20-2010, 10:22 PM
TheDustMan
Easy way to tell would be to buy a vacuum gauge and hook er' up. Make sure the vacuum source is POST-throttle, not pre-throttle. And if you need a little coercing to buy the gauge, let me tell you; if you take care of it, it will be a very valuable tool to have on hand in your garage. Useful for everything from detecting clogged exhaust to cam timing to misfires.
TheDustMan is offline
post #3 of 6 Old 01-21-2010, 08:09 AM
SeanB95YJ
by chance when you did the larger TB, did you also install a TB spacer? they're known to whistle, especially the power-aid ones with the helical bore.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 6 Old 01-21-2010, 09:31 AM Thread Starter
zhahn888
I did not use a spacer but i do plan on getting one soon... All we really have around here is a autozone could i get a vacuum guage there? Thanks again!
zhahn888 is offline
post #5 of 6 Old 01-21-2010, 09:51 AM
gojeep91
I did this once, I put the plate on backwards and it fit except for one spot in the back that it just barely overhung the gasket. It whistled pretty loud when under throttle but almost none at idle. This might be the solution, but might not.
good luck and let everyone know for future searches.
My simple '91 YJ build.
gojeep91 is offline
post #6 of 6 Old 01-21-2010, 12:46 PM
TheDustMan
They should, it's a pretty common piece of equipment. I would do the easy thing first and check your vacuum, tell us what the needle does at idle, when you rev the engine and let it settle back to idle, and then rev the engine to about 2000 RPM and hold it there.
4.0 engine whistle noise? BP88 TJ Wrangler Technical Forum 13 11-17-2011 06:20 AM
engine whistle after start-up jearnold JK Wrangler Technical Forum 8 02-22-2009 11:25 AM
2.5L engine whistle at idle Jeepdawgs TJ Wrangler Technical Forum 6 01-14-2008 06:57 AM
Whistle Noise Coming From Engine cardinalsfan06 TJ Wrangler Technical Forum 27 03-14-2007 12:26 PM
whistle in the engine winlit TJ Wrangler Technical Forum 2 02-16-2007 07:05 PM
