Engine vacuum lines.... Where to start?? - JeepForum.com
post #1 of 6 Old 08-02-2012, 05:05 PM Thread Starter
jsd1991yj
I purchased my 1991 jeep yj 2.5l with ax-5 last november. It did not have an engine and none of the vacuum lines were there. I bought a replacement engine 2.5l engine from a 1991 jeep yj and installed it a couple of weeks ago. I have been working on it a little here and there over the past 2 weeks. I am almost ready to fire it up for the first time since I have bought it. I am having a very hard time finding any information on the vacuum lines for the engine (not the front disconnect). Does anyone have any diagrams or photographs of vacuum lines they are willing to share?
Thanks for your replies.
Jeremy
jsd1991yj is offline
post #2 of 6 Old 08-02-2012, 05:55 PM
1SASjeepster
Jeremy,
You could buy a Chiltons or Haynes manual which should have that information in it. You could also do to ADDDATA.com which has all of the OEM manuals on it. You pay a small fee for access.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #3 of 6 Old 08-02-2012, 05:59 PM Thread Starter
jsd1991yj
I have the haynes manual and it does not specify the vacuum lines. It only says to properly mark them before disconnecting them so you can re-attach them. I also called my local jeep dealership and they do not have any manuals or diagrams avaialble.
post #4 of 6 Old 08-02-2012, 06:24 PM
1SASjeepster
Then I would check ALLDATADIY.com. They are a reference source for home mechanics and shops for OEM manuals. It is all available for $20-30 a year or for two years PER VEHICLE. Your information would be there. Wish you the best.
Take care,
post #5 of 6 Old 08-03-2012, 12:01 AM Thread Starter
jsd1991yj
Late night bump for any pictures??
post #6 of 6 Old 08-03-2012, 07:36 AM
Que89YJ
http://www.jeep4x4center.com/knowled...ex.htm#service
Look through the fsm in the link.
It's for a 93 but it will work.
Que89YJ is online now
Engine acting up. Vacuum lines shackjabe TJ Wrangler Technical Forum 6 12-18-2011 04:31 PM
Where can I find a diagram for the vacuum lines in the engine? wranglerbaby1 TJ Wrangler Technical Forum 0 04-26-2011 11:01 PM
Vacuum Lines / Diagrams / Trans & Engine CrushJeep YJ Wrangler Technical Forum 1 04-18-2010 09:36 AM
Vacuum Lines, Engine Swap AUGHHH!!! samahi72 YJ Wrangler Technical Forum 2 02-27-2006 11:45 AM
engine bay vacuum lines oldfrt47 YJ Wrangler Technical Forum 2 07-16-2003 09:21 AM
