Engine trouble...maybe some help? - JeepForum.com
post #1 of 5 Old 02-17-2007, 01:47 PM Thread Starter
tannermorrow
tannermorrow's Avatar
Hey guys. Over the past week or two I've noticed that when my jeep would first start up and I would take off that it would stall for a little bit when I would press the accelerator down it (this would go away after a minute or so. Went out to start the Jeep today and the jeep won't start at all now. It will just sit there and crank forever. When it first happened it acted like it was gonna start up on the first couple of cranks...but now like I said it won't start up at all now. Pulled the computer codes off and I ended up with the following...
12
33
52
21
55
Didn't know if these might help. Those codes have been on there for quite some time though. Nothing new. Would the oxygen sensor have anything to do with this?
Thanks for the help in advance!
tannermorrow is offline
post #2 of 5 Old 02-17-2007, 03:32 PM
NJeepyj91
check sensor ob bell housing: flywheel position sensor. With those codes I don't think you have spark.
NJeepyj91 is offline
post #3 of 5 Old 02-17-2007, 05:13 PM Thread Starter
tannermorrow
i'm in no way mechanically inclined can't do much more than change the oil, brakes and sparks.... could you or someone else possibly explain this (sensor ob bell housing: flywheel position sensor)?
post #4 of 5 Old 02-17-2007, 05:17 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
that was a type, it was menat to say,im sure, the sensor on the bellhousing...
at the rear of the motor, where it bolts to the tranny, there will be a wire going to a sensor. check that the wire isnt broken or anything.
i would disconnect the battery first to clear the codes, leave it disconnected for @5minutes, then reconnect and drive it.
the new codes will be genuine ones and not old stored ones.
the haynes book has a listing for the codes, if you havent got one, get one!!!
the codes will tell you where to look.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #5 of 5 Old 02-17-2007, 05:43 PM
Alfons
martin
That's an excellent suggestion. Try this and post the new codes.
One sensor that gives you a variety of symptoms, but in the end when it fails, stops the engine from starting. This is the Throttle Position Sensor (TPS), and is one of two sensors on the throttle body - very easy to change (connector & a couple of screws).
Alfons is offline
engine trouble greenmachine99 TJ Wrangler Technical Forum 7 01-03-2007 02:40 PM
Engine trouble aju4 TJ Wrangler Technical Forum 3 07-19-2005 08:05 PM
Engine trouble, PLEASE HELP Blackhole TJ Wrangler Technical Forum 5 07-12-2005 08:37 PM
Engine trouble... sgrim80 YJ Wrangler Technical Forum 4 02-04-2005 01:33 PM
Engine Trouble, Help Please? JSBlu974X4 TJ Wrangler Technical Forum 5 02-07-2004 08:11 PM
