Engine Trouble - JeepForum.com
post #1 of 17 Old 02-07-2014, 03:49 PM Thread Starter
DustyGeneral
Engine Trouble
1993 YJ 6cyl, it's my DD. Came home from work and parked, playing around in the garage and started it back up to fiddle with the heat controls. Ran like a dream. I shut it off and went inside to take a shower and when I came back outside to go somewhere she started and ran a little rough and the sputtered and died. When I went to start it again it would crank but not turn over. The fuel pump primes, but when we checked the spark the wire we checked didn't have spark. What should I be looking for?
I imagine that something is jacked up in the dist cap. Thoughts?
DustyGeneral is offline
post #2 of 17 Old 02-07-2014, 07:37 PM
Mark05059
are you getting fuel spraying from your injector
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 17 Old 02-08-2014, 03:34 AM Thread Starter
DustyGeneral
Haven't opened anything up to verify that, but I would assume so because when I turn the key for a few seconds you can definitely smell gas.
post #4 of 17 Old 02-08-2014, 05:16 AM
Mark05059
that doesn't really mean anything. The fuel pump will prime but if your crankshaft position sensor is bad it wont spray fuel or have spark.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #5 of 17 Old 02-08-2014, 05:20 AM
Louie4
Pull the plug wire off the distributor from the coil and see if you're getting spark there. If so, you'll need to check your distributor. If not, you'll need to check the coil and maybe the CPS.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 17 Old 02-08-2014, 06:01 AM Thread Starter
DustyGeneral
That's what I did and got no spark. So you're thinking coil and/ or cps
post #7 of 17 Old 02-08-2014, 06:08 AM
Louie4
Yes. You can check the coil with a volt meter. If you don't have one of those Autozone can also do it for free. You can also do the same for the CPS.
From my Haynes manual it says the resistance reading between terminals A & B should read 200 +/- 75 ohms (with engine at normal operating temps). A & B should be marked on the connector...should be.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 17 Old 02-08-2014, 06:21 AM Thread Starter
DustyGeneral
Haha and since it won't start I guess I can't test for it since I can't get it to operating temp...darn
post #9 of 17 Old 02-08-2014, 09:08 AM
fishadventure
...it would crank but not turn over...
what does this mean?
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is online now
post #10 of 17 Old 02-08-2014, 09:10 AM
Louie4
Yeah, that crossed my mind after the fact.
But wait...check this out.
http://www.cherokeeforum.com/f51/testing-cps-5563/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 17 Old 02-08-2014, 09:47 AM Thread Starter
DustyGeneral
Turn the key and it would crank, the starter would turn (vrvrvrvrvr) but not turn over (VROOOOM) and run haha... like my "sound effects"?
post #12 of 17 Old 02-08-2014, 09:48 AM Thread Starter
DustyGeneral
I have already thought it was the coil, just getting yalls thoughts.
post #13 of 17 Old 02-08-2014, 08:11 PM Thread Starter
DustyGeneral
Swapped the coil and she fired right up. The stock coil was cracked, funny thing was all of the cracks were on the back and underside so everything looked good from the outside looking in. But in reality it was beat to snot.
post #14 of 17 Old 02-09-2014, 06:09 AM
Louie4
Glad you figured it out and thanks for reporting back.
Oh and my link was for the CPS which is not the problem apparently.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #15 of 17 Old 02-09-2014, 06:36 AM Thread Starter
DustyGeneral
I always try to reply when I start a thread like this. It always bugs me to see a thread that I'm interested in and they never reply back to let us know how it turned out.
