Engine/trans swap problem with charging system - JeepForum.com
post #1 of 8 Old 06-25-2015, 06:34 AM Thread Starter
Plyj
I just finished putting in a 4.0L from a '98 XJ into my '90 YJ - also added a 700R4 transmission. Everything appears to be working fine except the charging system.
I had the alternator checked and 2 separate Auto parts places and both said it was fine. The old alternator had a plug that just plugged in but the new one ('98) has 2 studs and is supposed to have some kind of connector that is bolted onto the back. I just connected the wires to the studs since I don't have the connector thing. Is there something else I should be doing here?
Old Alt:
New Alt:
Thanks
Plyj is offline
post #2 of 8 Old 06-25-2015, 07:25 AM
fishadventure
I think the 98 alternator used the computer for voltage regulation while the earlier one is internal. I think that might be the issue. Can't remember for sure. Others?
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #3 of 8 Old 06-25-2015, 07:39 AM
jsawduste
2006 YJ Wrangler
Correct.
jsawduste is offline
post #4 of 8 Old 06-25-2015, 07:53 AM Thread Starter
Plyj
That would explain it.
But since I don't have a computer on this vehicle (converted the engine to Weber Carb) can I just add an external regulator?
I still have the old Alternator but would have to pull the V-belt pulley and swap in the serp belt pulley which could be more work than just adding the external regulator.
Thanks again.
Plyj is offline
post #5 of 8 Old 06-25-2015, 08:01 AM
fishadventure
The pulley conversion's been done. That's what I would do.
In fact if I ever finish my project jeep the peripherals wil be similar: 98XJ donor to '91 YJ
post #6 of 8 Old 06-25-2015, 08:02 AM
jsawduste
2006 YJ Wrangler
Correct x2
post #7 of 8 Old 06-25-2015, 04:06 PM Thread Starter
Plyj
Okay... thanks.
Ordered the pulley from Powermaster (old alternator mfg) since I couldn't get the OEM pulley off the '98.
Figured I could sell the other alternator and didn't want to ruin it.
I'll have to make new brackets... no big deal since I had to make 'em to fit the '98 alternator - as you can see from the photo.
Took it out for a drive today (carried an extra battery just in case) and she runs superbly... what a freakin pleasure... cruisin' at 70MPH without any strain.
I love it.
Thanks
Plyj is offline
post #8 of 8 Old 06-25-2015, 04:09 PM
jsawduste
2006 YJ Wrangler
alternator , charging system
