Engine and Tranny not lined up?! Non-stock tranny? - JeepForum.com
post #1 of 6 Old 06-29-2013, 02:41 PM Thread Starter
dcocch
Ok...so I was removing my intake manifold and exhaust manifold to replace the gasket and solve my coolant leak issue. After I got them out I was cleaning up the side of the engine and found this:
Is that supposed to be like that?!? It looks like I have a non-stock transmission AX15 maybe? Maybe this is the cause of my slow tranny fluid leak?
dcocch is offline
post #2 of 6 Old 06-29-2013, 04:23 PM
superj
Not the cause of your tranny leak but definitely weird.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 6 Old 06-29-2013, 05:04 PM Thread Starter
dcocch
Does anyone have a good way to tell the difference between the AX5 and AX15? I should have an AX5. I know my fill plug is on the passenger side which I thought was only on the AX5.
I'm stumped right now. Maybe Mean Max can make sense of this??
dcocch is offline
post #4 of 6 Old 06-30-2013, 11:24 AM Thread Starter
dcocch
So here is the bellhousing used in conjunction with the AMC 2.5L
It looks like the same one in the picture above with the squared notch on the right side. If that is the correct bellhousing for the AMC 2.5L, I am really confused. I can't figure out why there would be an opening going into the bell housing with two unused bolts in the pattern.
dcocch is offline
post #5 of 6 Old 06-30-2013, 03:56 PM
LJameson
My YJ has the stock drivetrain from the factory and is exactly like yours is in the picture.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #6 of 6 Old 06-30-2013, 05:41 PM Thread Starter
dcocch
Well then...I guess I'm freaking out over nothing. It was one of those things that I saw and said, "that definitely doesn't look right!"
Thanks for the clarification!
dcocch is offline
