-   -   Engine and Tranny not lined up?! Non-stock tranny? (http://www.jeepforum.com/forum/f12/engine-tranny-not-lined-up-non-stock-tranny-1542834/)
dcocch 06-29-2013 02:41 PM
Ok...so I was removing my intake manifold and exhaust manifold to replace the gasket and solve my coolant leak issue. After I got them out I was cleaning up the side of the engine and found this:
http://i1138.photobucket.com/albums/...ps9b8cc751.jpg
http://i1138.photobucket.com/albums/...ps13335882.jpg
http://i1138.photobucket.com/albums/...ps20c7333a.jpg
http://i1138.photobucket.com/albums/...ps498b56a4.jpg
Is that supposed to be like that?!? It looks like I have a non-stock transmission AX15 maybe? Maybe this is the cause of my slow tranny fluid leak?
superj 06-29-2013 04:23 PM
Not the cause of your tranny leak but definitely weird.
dcocch 06-29-2013 05:04 PM
Does anyone have a good way to tell the difference between the AX5 and AX15? I should have an AX5. I know my fill plug is on the passenger side which I thought was only on the AX5.
I'm stumped right now. Maybe Mean Max can make sense of this??
dcocch 06-30-2013 11:24 AM
So here is the bellhousing used in conjunction with the AMC 2.5L http://upload.wikimedia.org/wikipedi...ellhousing.JPG
It looks like the same one in the picture above with the squared notch on the right side. If that is the correct bellhousing for the AMC 2.5L, I am really confused. I can't figure out why there would be an opening going into the bell housing with two unused bolts in the pattern.
LJameson 06-30-2013 03:56 PM
My YJ has the stock drivetrain from the factory and is exactly like yours is in the picture.
dcocch 06-30-2013 05:41 PM
Well then...I guess I'm freaking out over nothing. It was one of those things that I saw and said, "that definitely doesn't look right!"
Thanks for the clarification!
The time now is 09:38 PM.
