Engine swaps........ - JeepForum.com
post #1 of 3 Old 05-29-2001, 01:39 AM Thread Starter
vw60
I have a 90 with the 4.2 and ax15 tranny. I was told that a 350 chev would bolt up to the tranny with out any adapters. Is that true? And will the stock radiator keep a 350 cool or will I have to replace that too? Thanks in advance, this board is the best place for info.
Thanks for the info Jay. I am trying to get by real cheap. I also have an amc 304 that I could put in. Anyone know how that bolts up? I would love to get by only having to change motor mounts.
vw60 is offline
post #2 of 3 Old 05-29-2001, 04:21 AM
Hara
good luck in getting any answers for that one I have a similar question out there right now, if someone drops some info your way do you think you could fill me in on the subject?
Hara is offline
post #3 of 3 Old 05-29-2001, 10:51 AM
93YJ
I considered this setup when doing my 350 swap, and was told that a new bellhousing adapter was necessary for the conversion to AX-15/Chevy 350. I wound up going a different route choosing an NV4500 behind a 350.
As for the radiator, I have the aluminum 4 core BeCool radiator and electric fan combo and still get a little hot when crawling. I wouldn't think a stock radiator would cut it. You might be able to get by with an electric fan on the front of the radiator, and a mechanical fan on the engine side. Good Luck!!
Jay
http://www.txtrailriders.com
93YJ is offline
97 4.0 engine replacement (Yes, another question on engine swaps) scott3294 TJ Wrangler Technical Forum 8 02-08-2010 09:33 AM
engine swaps mschuman YJ Wrangler Technical Forum 0 01-01-2009 12:49 PM
engine swaps b-coone1 TJ Wrangler Technical Forum 2 01-31-2008 10:40 PM
Engine Swaps Jeepdrivinmid TJ Wrangler Technical Forum 2 10-20-2005 09:17 PM
Engine Swaps... NIUPonyBoy YJ Wrangler Technical Forum 0 09-14-2004 11:15 AM
