Engine swap wirng harness - JeepForum.com
post #1 of 4 Old 06-22-2010, 12:01 AM Thread Starter
airdevil85
Is there a place online somewhere that can walk through the rewiring process of the engin harness for an engine swap?? Im in the process of getting everything around for mine... but dont know how to simplify/truncate the engine harness
1995 XJ - Totaled
1998 XJ - Totaled
1994 YJ - Sold
1998 zJ - Current
airdevil85 is offline
post #2 of 4 Old 06-22-2010, 05:05 AM
Que89YJ
What engine you are putting in would help.
Que89YJ is offline
post #3 of 4 Old 06-22-2010, 06:38 AM
markr1001
1987 YJ Wrangler
and what is coming out
markr1001 is offline
post #4 of 4 Old 06-22-2010, 06:58 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Even knowing the in/out motors, the answer to your 'is there a writeup' is probably No. There are just too many combinations of years and wires and wire colors, even in what you would consider a 'common' swap.
What worked incredibly well for me was subscribing to AllDataDIY.com for the motor vehicle and the Jeep vehicle. Then you can see what color wire from the Jeep goes to what color wire on the motor to power the computer, etc. I even got enough information and had the full wiring from the '02 motor I used that I was able to swap in the full '02 motor under-hood fuse-box and eliminate the Jeep box. That was pne of the best moves I made in the swap, because now I have a zillion available circuits and relays for whatever I do in the future (E.G. the Jeep does not have heated seats, but the fuse box has a spot for that, which can run the ARB system).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
engine swap wiring harness Peej03 TJ Wrangler Technical Forum 1 05-04-2010 07:18 PM
E-fan wirng question czjeeper YJ Wrangler Technical Forum 9 02-24-2010 10:01 AM
92 Wiring harness toasted/engine swap wrose95174 YJ Wrangler Technical Forum 1 03-21-2009 07:32 AM
Radiator, Wiring Harness, Headers for V8 Engine Swap simpsonsdotcom TJ Wrangler Technical Forum 15 04-24-2008 11:12 AM
1990 YJ Engine Swap - Harness Q Fred007 YJ Wrangler Technical Forum 3 10-14-2007 09:22 PM
