engine swap question - JeepForum.com
post #1 of 6 Old 12-15-2011, 03:07 PM Thread Starter
Holtcjh
I have an 88 YJ with the 2.5 liter 4cylinder in it. Well I threw a rod through the oil pan yesterday driving down the highway. so I need to replace it, I have someone with a 82 wrangler (Guess its a yj) that has the 4.2 liter v6 in it. Just curious as to if anyone has done this swap before and how much trouble would it be to install the 4.2 liter. Does it even fit?
Holtcjh is offline
post #2 of 6 Old 12-15-2011, 03:12 PM
scubamc
If it's an 82 it is a CJ. The 4.2 is an inline six not a v6. Plenty of swaps have been done. It will fit. you will need new motor mounts, the computer, harness and the list goes on. might be easier to sell your YJ and buy one with a 6.
scubamc is offline
post #3 of 6 Old 12-15-2011, 03:20 PM Thread Starter
Holtcjh
well the guy only wants 600 for the whole 82 CJ, the interior is screwed and the tub is rusted out the bottom. Would the hard top and doors and stuff for the 88 fit on the 82? I might just go that direction if so and take all the parts I can off the YJ and fix up the CJ. might be easier than going through all that jazz to put the inline 4.2 in the YJ.
Holtcjh is offline
post #4 of 6 Old 12-17-2011, 12:10 AM
Kowalski
That's a really great deal for the CJ.
as far as matching parts...their almost all the same.
you can even replace the fenders, dash, top, doors, and engine easily. They're both carb'd, so an engine swap would be pretty easy. but your transmision in your 88 won't fit a 4.2, so that would have to go.
Kowalski is offline
post #5 of 6 Old 12-17-2011, 12:40 AM
SnowdogMarc
I have to say if the tub and other YJ parts will fit the CJ I'd go that route so the drive train won't have to be touched. I just did a 4.3 V6 swap with an Ax-15 in mine. For the people saying it's better to just buy one with a 6 in it already because it's too much work...it really isn't. Yes you do have to remove the 4 cyl mounts and get new ones welded on, mod the skid for the new tranny and shorten the rear drive shaft. Other than that it's just wiring the new computer and harness to your Jeep. If you have all the parts and tools to do it you can get it done in just a few weekends.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #6 of 6 Old 12-17-2011, 06:37 AM
YJames90
YJames90's Avatar
Its not too much work. I figure I have around 600 hours into the swap so far. . Thats me alone from this past June until now.
be ready to spend alot of cash
The swap is worth , ever see a YJ do a posi burn out on 33s ?
My 2.5 to 4.3 swap thread
YJames90 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
engine swap question cavtrooper TJ Wrangler Technical Forum 0 11-06-2007 06:36 PM
engine swap question ltdanyj YJ Wrangler Technical Forum 12 11-09-2006 07:59 PM
engine swap question 72cj5er YJ Wrangler Technical Forum 4 03-01-2006 08:46 PM
