Engine swap nightmare - Page 2 - JeepForum.com
post #16 of 24 Old 08-16-2011, 08:38 PM Thread Starter
Bulldogbuggy
Did it! Don't know what did it but whatever you guys told me to do WORKED!
Then I found a gas leak at the injector where I got one of the o rings in a bind and pinched it. Replaced it and now no leak JEEP runs!
Now to the new problem!
Now it hesitates when I press the gas and I have an oil leak at the valve cover(gasket) gonna replace the gasket!
May move over the plug and wire set from my old engine (just put them on) not sure what could be causing the bogging down.
Bulldogbuggy is offline
post #17 of 24 Old 08-16-2011, 09:23 PM
oldtime_ironman
Great! That will make it a lot easier to figure the rest of it out!
Questions:
Are there any codes stored in the computer?
Is all the vacuum hooked up OK? No leaks? Leaks can cause all kinds of funky weird stuff.
oldtime_ironman is offline
post #18 of 24 Old 08-16-2011, 09:26 PM
oldtime_ironman
Questions:
post #19 of 24 Old 08-17-2011, 06:17 AM
nzpete
I'd also replace the fuel filter, if you haven't already.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #20 of 24 Old 08-17-2011, 06:44 AM
dodger889
Fix leak then test again. Even the smallest fuel leak could cause a problem.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #21 of 24 Old 08-17-2011, 08:43 AM Thread Starter
Bulldogbuggy
Fuel leak fixed, vacuum lines all hooked up, now I am installing new valve cover gasket! Also gonna swap out throttle bodies to see if it is all the gunk built up on this one! Hell I got a whole other engine to rape and pillage! Thanks JF!
post #22 of 24 Old 08-17-2011, 08:52 AM
oldtime_ironman
Gunk in the throttle body will do it. Whatever one you use, you should get some solvent and a brush, and clean it out real good. I bet you'll be surprised how good it works. I just found out yesterday that the IAC is working all the time when its running - not just when it starts!
post #23 of 24 Old 08-17-2011, 08:31 PM Thread Starter
Bulldogbuggy
And DONE running great I mean great no shake, shimmy, hesitation, lull, bogging down, no check engine, the Maint REQ. Light comes on occasionally what does that? When it does come in there is nothing different happening just running awesome Need some gear oil too! Had the rear drive shaft out and lost a good bit while I was pulling it to the house when I got it.
Got a block with good head gasket, and all the old crap of my other engine! The crank needs to be turned (spun bearing) willing to part the whole thing out. Let me know I will give you my contact info! I am in eastern north Carolina will ship you pay for it!
post #24 of 24 Old 08-20-2011, 11:14 AM
Roadyy
Check for codes and I'll bet you get an O2 sensor code. Either the sensor is going bad or you have a small exhaust leak somewhere causing a bad reading. Replace the sensor which is just under the passenger door in the down pipe and see if it comes back later. If so then check for exhaust leak or clogging cat.
Roadyy is offline
