engine swap advice needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > engine swap advice needed
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-11-2007, 06:49 PM   #1
three
anyone have any info or experience with a 351w into a yj? or a 5.0?
how does this compare to the SB chevy swap?
any good advice other than buying swap parts?
does anyone have any real experience with the performance increases as far as the 4.0 --> 4.6 stroker goes?
thanks in advance
three is offline   Reply With Quote
Unread 04-11-2007, 07:42 PM   #2
three
engine
bump bump bump
Unread 04-12-2007, 09:08 AM   #3
David K.
Do you have a 4 or 6 in there now?
To go to the V8 you are adding 2-5K to the cost because of hte axle.
If you already have a 4.0 and are feeling up to it, buy a $600 4.0 from the bone yard and stroke it yourself. I forget who, but there was talk a month ago about someone doing the budget 4.5 or 4.6 themselves. You could do that for short money and not do the tranny till it broke, if it broke. Not to mention the welding that will be involved with a non jeep engine.
You could do that for such cheap money compared to the 351/302 that will need axles, tranny, tcase adaptor, something to interface with the guages, shifters/ linkage and wiring. All that on top of an expensive engine.
What ever you do, from my experience (ongoing 4.3) I would def. get the same model year engine as the one you are replacing. All the money you save by stroking you can put into performance parts. IMHO
David K. is offline   Reply With Quote
Unread 04-12-2007, 09:22 AM   #4
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
sounds like you are not having fun dave? just finished building showmejeep's bored 4.3 yesterday, just need valve covers and accesories installed... to do a tbi, its a lot easier than the cpi motor that you went with...
$$ on the donor, $300 wiring, $140 motor mounts, and thats real close for a tbi swap! i have @$1600 in mine, and still have the donor to sell. i'd say more reliable hp than a stroker motor too, just my opinion there though....
you'd need a new rear axle regardless of the stroker/swap decision, so thats not a consideration here.
bring that thing to Mo and we'll get it figured out for ye dave.... or take it to NY and let don get it finished for ye, think we'd both work for alcohol...
OP, keep us posted on your decisions, and take plenty of foto's to post up!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Unread 04-15-2007, 08:19 PM   #5
three
motor
well
i already have an 8.8 and everything needed for that
my buddy is welding the tubes on that right now
also..
my other friend and his father own a machine/engine shop
so i can get stuff for whatever i am doing at jobber pricing
just wandering if it was worth the trouble for the stroker
numbers are great to read but i wanted some input from someone who knows if there is a real increase when workin the 4.0 or if i might as well go ahead with a chevy or ford small block
thanks for the info
Unread 04-16-2007, 06:27 PM   #6
89YJmoneypit
KMG365
89YJmoneypit's Avatar
There was a huge thread on a 5.0 swap a while ago:
http://www.jeepforum.com/forum/showt...ghlight=5.0%2A
I didn't bother to read all the way through all 16 pages, but I'm sure there's some info in there somewhere . If you do a search for "5.0*" and "stroker" there's a few more threads out there.
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
Was my daily driver, now son's college wheels.
Marseilles Fire Dept: http://www.flickr.com/photos/4461494...th/7659346164/
89YJmoneypit is offline   Reply With Quote
