Engine Swap????? - JeepForum.com
post #1 of 5 Old 03-07-2002, 11:42 AM Thread Starter
92Wrangler15
Engine Swap?????
I have the four cyclinder jeep engine, and I was wondering what I would need to switch it to the 6 cyclinder engine?? I dont want the v8 because of the gas milage. Would I need to switch the engine, transmition and ECU????
And how much would it cost??
Also I'm getting a 2.5 inch lift and I was wondering what size of tires I could fit in there?? And how wide can I go???
THANKS FOR HELPING OUT A NEWBIE.
1992 YJ, 4 cylinder STOCK (trying to get the 6 cylinder in)
92Wrangler15 is offline
post #2 of 5 Old 03-07-2002, 12:44 PM
Steve-0
2009 JK Wrangler
Just having transmission work done and trying to find the parts, I know that if you go from the 4 banger to the 6 cyl. you HAVE TO CHANGE THE TRANSMISSION!!!! It is an extremely expensive project and you might as well just look around for a different Jeep (unless you are like me and will never part because of sentimental reasons). Price considering, I'm looking at a V8, axle swap, tranny, T-Case, the worx... Good luck...
Drinking for the cause.
Join Date > Post Count
Steve-0 is offline
post #3 of 5 Old 03-07-2002, 01:22 PM
dennisuello
dennisuello's Avatar
Originally posted by 92Wrangler15:
...Also I'm getting a 2.5 inch lift and I was wondering what size of tires I could fit in there?? And how wide can I go???
with 2.5 lift you'll be able to fit 32s with some rubbing when flexed. 31s without rubbing.
dennisuello is offline
post #4 of 5 Old 03-07-2002, 01:51 PM
Loppy
IMHO, dont polish another turd. Go V8 and be done with it. Best mod I ever done did.
DisFUNctional.
Loppy is offline
post #5 of 5 Old 03-07-2002, 03:30 PM Thread Starter
92Wrangler15
How much would it cost to do the swap?? How much for the engine and transmition?? I can put the engine in with some help. Would I also need a new ECU???? Would I be able to keep the swap under 3k???
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 03:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
some ?s on engine swap or trans swap mdf27 YJ Wrangler Technical Forum 3 06-07-2008 09:24 AM
Engine 4.3L swap and axle swap abrupt11 YJ Wrangler Technical Forum 14 02-18-2005 11:14 AM
