engine swap-4.0 97 comanche to 2.5 97 yj - JeepForum.com
post #1 of 3 Old 01-20-2012, 05:11 PM Thread Starter
skeeter97
1997 MJ Comanche
would like to install a rebuilt 4.0 out of my 97 comanchi to my newest purchase, a 97 yj with a bad 2.5. both have ax15 trannys and transfer cases match. question, will they bolt in without modifications, will the icu units exchange without rewiring the whole harness, will i have to change radiators. thanks for your thoughts.....
skeeter97 is offline
post #2 of 3 Old 01-20-2012, 05:18 PM
superj
do you mean 87?
i have read the 4.0 won;t bolt directly to the other trans, have to change the bell housing or something but since you have the complete truck to swap from, it should be easy to do
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 3 Old 01-20-2012, 05:24 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
me suspects another troll may have crawled out from under a bridge.
Back Road Jeepin
BackRoadJPin is offline
Comanche engine? pcw977 YJ Wrangler Technical Forum 3 01-15-2012 04:04 PM
Need HO swap asap from a wrangler to comanche tonythehazelnut YJ Wrangler Technical Forum 1 07-15-2011 09:00 AM
2.1L I4 Comanche Diesel Swap Questions JeepLess YJ Wrangler Technical Forum 3 09-06-2010 05:48 PM
TJ engine and trans into Comanche gaucho919 TJ Wrangler Technical Forum 0 01-11-2010 09:23 AM
YJ into Comanche rear end swap? Karnage YJ Wrangler Technical Forum 1 05-30-2003 12:47 PM
