Engine Swap... - JeepForum.com
post #1 of 11 Old 10-17-2010, 04:20 PM Thread Starter
HooahYJ
Engine Swap...
Sorry for the noob question but i am unable to find the answer...
I have a '95 YJ with a 4 cyl. engine factory transmission and factory axle.
I want to swap in a new engine something bigger then a 4 banger.
What engines would be best for me to swap in and when i do what all will i need to go with it.. EX: transmission, computer, axles....
And where would be the best place to get what i need
Jeep.... If I Wanted A Hummer Id Ask Your Sister....
HooahYJ is offline
post #2 of 11 Old 10-17-2010, 05:07 PM
TheNewbie
A 4.0 from anopther Jeep woule be the easiest and probably the cheapest way to go. You can buy a donor vehilce and take the drivetrain and computer/wiring harness out and swap it into your Jeep.
You'll have to relocate your motor mounts too.
http://www.jeepforum.com/forum/f12/4...mation-537763/
Read here and you'll have all the info you should need.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 11 Old 10-18-2010, 11:13 AM
idolax
TheNewbie will let you use his guns and you go to the store and take the parts and all the cash. (sell the yj and buy a jeep you want) I'll take your four cyl mine died i need an ez swap!
idolax is offline
post #4 of 11 Old 10-18-2010, 06:27 PM Thread Starter
HooahYJ
Yea thanks for the replies but as bad as it hurts me to say i think you are right. I think i should just get a new jeep instead of goin through all the trouble
HooahYJ is offline
post #5 of 11 Old 10-18-2010, 08:58 PM
dodger889
You might find a new frame that is setup for a I6. That would work. Change over the rest to it.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 11 Old 10-18-2010, 11:25 PM
TheNewbie
Or before going to all that trouble just look into re gearing the axles. That might give you what you're looking for.
post #7 of 11 Old 10-19-2010, 12:56 AM
intub8u
You want to win races? Or do you want to have a capable off roader? I say spend the money you would spend on a 6cyl or swap and mod your existing ride the way you want. re-gear, stronger axles, lift etc etc etc etc.
intub8u is offline
post #8 of 11 Old 10-19-2010, 07:42 PM Thread Starter
HooahYJ
Is ther any way to tell what your gear ratio is?? I bought my jeep already with mods EX lift etc. And im not sure the guy changed the gear ration when he installed 33s
HooahYJ is offline
post #9 of 11 Old 10-19-2010, 07:51 PM
steinmetzme
first off are you able to use 5th gear when going down the road? if not then he never changed the gears. I have a 4 banger and have switched to 4.56 gears and upgraded the rear to a detroit locker and the front has an Ox selectable locker in it. also the rear has superior axle upgrade in it. also put on a header and a cold air intake onto it and over all it runs pretty damn good. can actually get up to around 80 mph and my fuel mileage is between 15-16 mpg depending on how i am driving it and whether my road rage is kicking in.
steinmetzme is offline
post #10 of 11 Old 10-19-2010, 09:17 PM
TheNewbie
That's the "easy way" to tell. Or you can jack it up so that the tires are off the ground and turn the wheels while counting how many times the driveshaft turns for every rotation of the wheels.
Stock you more than likely had a 4.10 gear ratio. Going to 4.56 or better yet 4.88 would help a lot.
I'm still rollin' the 4.10's with a 4 banger and 33's myself, but if I had more time and money gearing would be on the top of the list.
post #11 of 11 Old 10-20-2010, 06:42 PM Thread Starter
HooahYJ
Yea i am able to use 5th going down the road. And it seems to me that my 4 banger doesnt have to much problem on the road. Offroad you can tell its a 4 banger a little bit. But defintly going to get a new jeep with larger engine now that i have the wife's approval hahaha
HooahYJ is offline
engine swap
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 03:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 02:08 PM
Engine Swap or Body Swap? schecterguy YJ Wrangler Technical Forum 2 09-27-2008 11:36 PM
