Engine Still Overheating After Water Pump Replacement
#16 | |
i think id rather touch the fan blade off a jeep then 1 off my old blazer in Wisconsin.... that might take a hand off ahaha
1994 yj. lifted 4 inches locked, loaded, and armored! Member of Great Lakes Jeep Thing and supporting jeeps gone wild |
#17 |
May sound dumb....but make sure they sold you the right water pump. I had a yj that I bought that would overheat but I knew the engine needed rebuilding also. Right after we put in the new engine and new water pump it immediately ran hot. Come to find out on the one we had the blades on the inside turned one way and the one we needed they turned the other. Got a different water pump and no more overheating problems. It sounded stupid to me too, but after switching the problem was gone.
#18 |
Got my eye on you.....
Looking for it now.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#19 |
[I'm That Good]
Thanks for the check tips on the fan clutch. I'll try that out today when I get back home.
I'm interested in seeing this thread as well.
Pimptiva.com |
#20 |
[I'm That Good]
Alright... I got a new fan clutch... Put it in last night, but I think we may have mounted the fan fins backwards.
I removed it this morning, but then got really confused because there is "front" written on the one side... Does that mean it goes towards the front of the Jeep, or the front of the engine? By looking at my Hayne's manual (page 3-5, picture 5.9) - If I put my fan that way (so that the rivet screws back piece is towards the engine), then the "front" text on the fan is facing the engine, not the front of the Jeep. Before replacing this piece. My fan really blew air back onto the engine. Now it seems to be forcing its way at the radiator and shroud. I'm guessing that I have it on backwards... But, I got confused by the "front" text on it. Can someone confirm that "front" should be facing the engine? Thanks...
Pimptiva.com |
#21 |
On permanent vacation....
If the fan is not sucking air from the radiator and blowing towards your engine, then you installed it backwards.
#22 |
[I'm That Good]
Over lunch, I went home and compared the old fan clutch to the new one. I put the fan back onto the old unit, the same way it came off (compared the "marks" that the bolts left). I did install it the same way as it was before. That means the front text is facing the front of the vehicle.
Is it possible that the thing is spinning the wrong way by chance? What way should the fan spin when the engine is running? Clockwise or counter clockwise?
Pimptiva.com |
#23 |
I feel your pain man. I went over this for months. See my thread. i have pictures too.
http://www.jeepforum.com/forum/f12/jeep-still-over-heating-even-after-head-job-468565/
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers, 2000 Corvette Roadster: Almost stock http://www.demonoff-road.com/ 2002 Avalanche: To many mods to list |
#24 |
[I'm That Good]
Ouch... Hopefully I can get away with less pain than that...
I'm going to check the belt routing, direction of the fan and stuff tonight when I get home from the office.
Pimptiva.com |
#25 |
[I'm That Good]
Alright... The belt is routed properly... I reinstalled the old fan clutch, exactly the way I removed it.
The fan is STILL pushing air against the radiator isntead of pulling it back towads the engine. Does anyone this this could be because of having the wrong water pump installed? I'm looking at the water pump pulley... The belt goes around it and makes it turn clockwise... If I have a reverse water pump, will that make the fan spin clockwise, or counter clockwise? I'm at a loss here... I guess I'm dropping it back off at the shop tomorrow and I'll have him look at it. If anyone has suggestions for me to tell him, I'd appreciate hearing them.
Pimptiva.com |
#26 |
[I'm That Good]
Well, I went down to my neighbors a block down the street from me. He's got a TJ with the I6 as well, so I took a peak at his radiator fan setup... It's the same as mine, and blows air the same as mine. So, I'm guessing that it IS right after all, and I'm just losing my mind.
Hopefully the tstat will fix the overheating problem now. ![]()
Pimptiva.com |
#27 |
I had the same issue when I bought a new waterpumo which rotated in a wrong way and there the problems began.
Check that you have the right waterpump.
Jeep Wrangler 2.5L 1989 |
#28 | |
this is a pretty common problem with the YJ's.........just be thankful you don't have an XJ with closed system cooling! I'd betcha money that the Jeep isn't running hot at all.......sounds to me like air in the line. One way to tell is if you can hear water trickling down the heater core when it's cold?? Take the radiator cap off and start the jeep. Make sure the Jeep is cold before you do this......let it get up to running temp...you will notice air bubbles coming out the top of the radiator and probably coolant too. Just let it idle about 10-15 minutes and keep topping it back off with coolant. When the bubbles stop appearing, problem should be solved. Let me know if this doesn't work......
#29 | |
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels. Caution!!! Under construction!!!!!! Caution!!! Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD! |
#30 | |
something is wrong here. I'm no where near my jeep so I can't confirm this, but the fan should be "pulling" air through the radiator, not pushing. Heavy equipment, generators, etc. push air through because they either don't move or move real slow. Cars on the otherhand, move fast so they usually pull air via the fan and are assisted by the speed of the vehicle. maybe i've lost my mind though?
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
