Engine Stalling - JeepForum.com
post #1 of 4 Old 06-12-2004, 01:14 PM Thread Starter
TSEJEEPERS
Engine Stalling
93 4.0L Manual Trans. My engine stalls at a stop with the clutch pushed in. It seems to do it when the engine is at normal operating temps. The rpms will fall way down then it will stall. I have new plugs, wires, distubuter cap, thottle position sensor. I thought maybe it was a vacume leak but I can not find one anywhere. Any ideas? It does have the original o2 sensor would that have anything to do with it? Oh and no check engine light comes on.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #2 of 4 Old 06-13-2004, 08:26 AM Thread Starter
TSEJEEPERS
Anyone?
post #3 of 4 Old 06-13-2004, 08:54 AM
KEVNISE
maybe you have a clogged converter that's what I would check first , When you r driving your rpm's are up high enough to blow by the converter when you stop it suffocates the motor?
90 wrangler weber carb nutter bypass 4" lift pro comp 4.2 liter 33" muds 411 gears
69 camaro
KEVNISE is offline
post #4 of 4 Old 06-13-2004, 04:52 PM Thread Starter
TSEJEEPERS
The catalic converter is long gone. Anyone else?
Engine stalling, No check engine light gpdaddyo1 TJ Wrangler Technical Forum 1 04-06-2011 09:11 AM
Engine stalling redmen07 TJ Wrangler Technical Forum 0 09-07-2008 02:10 PM
Engine stalling AL1951 TJ Wrangler Technical Forum 22 04-18-2007 09:24 PM
Engine Stalling JeepTodd YJ Wrangler Technical Forum 1 10-22-2001 06:09 AM
Engine Stalling Nine5YJ YJ Wrangler Technical Forum 2 03-10-2001 12:45 PM
