Engine sounds funny... - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Engine sounds funny...
Amsteel Blue Synthetic Winch line Free ShippingTravelling with Pets?Steering and more from Ruffstuff!
Unread 03-27-2012, 11:32 AM   #31
Beachcruiser
1987 YJ Wrangler
Originally Posted by CBinDC View Post
I've noticed when I initially doing the timing everything sounds fine. Its when I reconnect the distributor vacuum advance is when I start to hear the problem. If I disconnect it, I don't hear the sound.
There's your sign that you have too much initial advance. The manifold vacuum is adding too much for that base setting of 8 BTDC.
Every engine is different as far as what the timing marks actually read. Pointers/marks can be off of true top dead center. 8 degrees is just a starting point. Feel free to change it til YOUR engine runs well...then adjust the carb.
probably out breaking stuff.
Beachcruiser is offline   Reply With Quote
Unread 03-27-2012, 08:01 PM   #32
CBinDC
CBinDC's Avatar
Thanks. I appreciate you chiming in to add that. What does that mean? I should set my timing lower than 8 btdc? I've always thought the engine sounded better when set lower.
Anyways, back to my real issue. What causes the problem with my acceleration? Is the mixture too rich or too lean? Could it be the accelerator pump? Because I'm having the problem when I am accelerating. What about the fuel pump?
CBinDC is offline   Reply With Quote
Unread 03-28-2012, 08:07 AM   #33
CBinDC
CBinDC's Avatar
Can anyone help me with this??
