engine shuts down - JeepForum.com
post #1 of 2 Old 11-29-2011, 08:19 PM Thread Starter
yj92geep
engine shuts down
new to forum and jeeps , I have a 92 YJ 2.5 5spd. going to work one day and it just died . talked to some people and they told me to change the CPS
So i did and it ran fine for a while . but now when you start it and drive it for a couple mile it will shut down . Let it sit for a hour and it will start back up and a couple miles later shut down again . I can even start it in the drivway and let it idle for awhile and it will shut down just sitting there . Let it sit awhile and it will start again . would the new CPS be faulty .
yj92geep is offline
post #2 of 2 Old 11-30-2011, 12:51 AM
moonshinefuel
possible ecm
I would test for the check engine light codes. If ot does not perform the sequences, I would look at possible ecm problems.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
Engine shuts off when I hit a bump percent20 TJ Wrangler Technical Forum 17 12-28-2011 11:52 PM
Engine just shuts off. Schwalby TJ Wrangler Technical Forum 2 02-01-2011 07:49 AM
Engine shuts off sccabrian TJ Wrangler Technical Forum 5 10-29-2007 08:05 PM
engine intermittently shuts down saharaflyer YJ Wrangler Technical Forum 3 08-05-2002 09:49 AM
engine shuts down while driving jamesscott YJ Wrangler Technical Forum 5 02-03-2002 01:13 PM
