Engine Serial Number - JeepForum.com
 1Likes
post #1 of 27 Old 04-07-2009, 05:19 PM Thread Starter
moonshinefuel
I would like to decipher an engine serial number. If anyone knows how I can do this to figure out what engine exactly this was that would be great. I figured out the CASTING number near the coil behind the distributor 53008403 is from 1991/95 era jeep, but there is a 7 digit serial number stamped into a machined surface in the side of the block under the a/c mount bracket. Any ideas to help me narrow this down a little more from that number to find the exact year this is? And for what jeep? etc. Is this possible from the stamped serial number?
moonshinefuel is offline
post #2 of 27 Old 04-07-2009, 05:37 PM
TheNewbie
I just always type the # into google and something usually comes up for it.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 27 Old 04-07-2009, 08:23 PM Thread Starter
moonshinefuel
thanks, worked for the cast # but not the serial #
post #4 of 27 Old 04-07-2009, 09:38 PM
Old4X
1990 CJ7
The stamped number isn't a serial number, it is a build date code.
It translates to the year and day of production and the engine type
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 27 Old 04-07-2009, 09:51 PM
Old4X
1990 CJ7
The digits of the code identify:
1. 1st digit - the year (e.g., 4 = 1994)
2. 2nd and 3rd digits - the month (01-12)
3. 4th and 5th digits - the engine type/fuel system/compression ratio
(MX = a 4.0L 8.7:1 compression ratio engine with multi-point fuel
injection system).
4. 6th and 7th digits - the day of the month of engine build (01-31).
Old4X is offline
post #6 of 27 Old 04-07-2009, 10:43 PM Thread Starter
moonshinefuel
here are the numbers: 609hx20. What year engine is this? I am going bonkers trying to dissect all of these digits and google is not helping me. This is an assembly line engine and has never been installed in a jeep. It's new old stock basically. Can anyone break down the entire code and all its specifications?
post #7 of 27 Old 04-07-2009, 11:39 PM
mtn_wrangler
well according the the description right above your post it was made spetember 20th of 1996.
mtn_wrangler is offline
post #8 of 27 Old 04-08-2009, 11:34 AM Thread Starter
moonshinefuel
thank you all for the help!
post #9 of 27 Old 06-16-2009, 02:40 PM
justin_92_92
Hey all,
Mine looked more like this, IIImx18
It looks like the letter "I" but may be the number one?
So mine must be november 18, 1991 hmm...figures why I couldnt get some parts to fit.
justin_92_92 is offline
post #10 of 27 Old 07-19-2009, 01:03 AM
DriveTooMuch
DriveTooMuch is offline
post #11 of 27 Old 07-06-2011, 08:44 PM
JMAC90YJ
JMAC90YJ's Avatar
The only thing I could find was this machined block right behind alternator, Doesn't look like enough numbers, My wife took the picture with her phone and this is the besst we could get it.
Can anyone decipher?
JMAC90YJ is offline
post #12 of 27 Old 07-06-2011, 08:59 PM
Opihi59
from here it gets rough
Opihi59's Avatar
The HX is coming up as this: HX = a 2.5 liter = [150 CID] 9.1:1 compression ration engine with a multi port fuel injection system.
It is a 4 banger, right?
So not too certain I'm going to be real helpful here, but didn't the MPI not come out in the 4 banger until 2000? It was CFI prior. I don't know what the code was for YJ era 4 bangers, so is it possible this is from an engine manufactured in 2006 and not 1996? But Jeep went to a 2.4L 4 cyl in 2003, right? Maybe a few Jeepers from the 2.5 club who know their engines to be original from the YJ era and tell us if it says HX or something else?
I'll keep looking.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #13 of 27 Old 07-06-2011, 09:13 PM Thread Starter
moonshinefuel
Yes, a brand new 2.5 engine, not rebuilt, but brand new off the assembly line.
AX5/NV3550 Conversion Thread.
Bow Hunting
post #14 of 27 Old 04-16-2013, 06:24 PM
Stephen84
1978 CJ5
I havehave a 78 CJ 5 The code on mine is 11CL10 can someone tell me what engine mine is
Stephen84 is offline
post #15 of 27 Old 04-16-2013, 07:10 PM
Stephen84
1978 CJ5
Mine has a plastic valve cover and a aluminum intake i was told they started putting that on in 81 i just want to know what it is so i can order parts
Can someone decode this engine number for me Reverb YJ Wrangler Technical Forum 18 10-28-2016 11:50 AM
Decoding engine number Azboy YJ Wrangler Technical Forum 7 06-18-2015 09:43 AM
2001 engine block number HolidayJeep TJ Wrangler Technical Forum 19 11-11-2008 03:44 PM
Serial Number Search Douglas S. YJ Wrangler Technical Forum 3 02-23-2008 11:06 PM
95 YJ Can someone check on a serial number for me? baymen4life YJ Wrangler Technical Forum 4 10-23-2007 06:07 AM
